3,238
Member
5,516
24
  • [WIP] Cliff City B&W
    Getting there, I think!
    There are still problematic shadows with the three eastern, smaller mesas from the bridges, and the eastern cliffs. Looking at your FCW file, I'd assumed you'd already drawn white polygons for the cliff tops, but I see that's not the case, so my advice in my previous posting will only partly work. Those pesky grey areas, which I discovered are on your "Cliff Cover" Sheet, have obviously helped where they are, but equally not where they aren't!
    As this is the template for your drawing style, I'd suggest using that Cliff Cover Sheet as the place to draw white (colour 15) polygons for ALL the clifftop areas. This should mean you can use the technique I'd proposed for things like bridges anywhere you like without it causing problems with the shadows in future drawings. Such polygons will need to be drawn carefully to avoid losing the cliff-edge line on the cliff symbols, because the polygons must fill the whole clifftop area, and lie above the cliff lines themselves so the bridges can cast shadows on the cliffs, but not on the clifftops. This will also let you place bridges anywhere you wish, of course.
    JulianDracos
  • Forum oddities in recent days
    Well, this evening's "fun and games" with the Forum took a while to get started, but suddenly I've just had two events occur one after the other - "A temporary error occurred. Please retry." boxed message at the lower left of the screen. One happened when I tried to click to "Like" a posting, the second when I wanted to add a typed comment.
    And while I was typing this, I've just had another, though unless that was the system failing its autosave roll, I have no idea why - no, it's just done its autosave OK - because I wasn't even typing at the moment it appeared! It's still on-screen now (but I haven't clicked to close it yet, as I wanted to make sure I copied the message correctly).
    So, the Gremlins have changed tack, but clearly, they're still here. Someone's been feeding them after midnight, perhaps...
    Need longer arms Jim ?
    [Deleted User]JimP
  • Most of my sheets won't show effects
    More importantly, have you managed to resolve the issue?
  • The Lost Vault of Tsathzar Rho
    @jmabbott asked:
    Is it possible to get a curved line with double arrows as in the original posted above?
    Yes. Rather than try to explain it, look-up "arrows" in the CC3+ HTML Help file using Search, and have it display the "Double Arrow" entry. For some reason typing "Double arrow" in the search bar comes up with nothing...
    You can add arrows at both end of a straight, arced or smooth path/line. As we've noted here before though, depending on what size of arrowhead you need, you may be better off drawing the line, adding filled polygon triangles for the arrowheads, and placing them separately yourself, as the automatic system can show the line extending beyond the arrowhead sometimes.
    jmabbott
