- Wyvern
- 3,238
- Member
- 5,517
- 24
WIP: D&D 5e Random Dungeon Tiles
As with other things taken as "universal beliefs" by many (especially elsewhere on the Internet...), the spiral-staircase thing seems to have been a purely late Victorian/Edwardian speculative invention; see this usefully-referenced blog posting, for example.
Annual No 1, Issue no 8 - My example of the Spaceship style.
Interesting. I can though see problems from a practical military usage and command perspective.
The weapons are mounted too high up. A couple of options on the lower and/or upper deck would be OK for aerial threats. There needs to be another weapons position in the hold for tackling lower aerial and ground threats, however.
The bridge at only the rear of the upper deck is OK for a secondary command position/emergency bridge. There needs to be another and main bridge higher and/or further forward though, and observation positions (ports at least) at various places on the lower and hold decks, as visibility is purely upwards over most of the craft currently. The hold could also use a bomb bay for vertical delivery of heavy ordnance, and as a crew escape mechanism.
There's a lot of wasted space on the lower-upper deck in the middle of the craft where the masts run through (and what are those stacked (?) grey squares there?). Does this whole area need to be so open? Or could the stores and crew quarters not be moved into here? Ordinary crew don't need individual quarters either, plus there aren't enough crew. Leaving aside any practicalities of using only upper sails as propulsion on such a craft anyway, for masts this size, you'd need at least four crew, and you should have at least as many observers/signallers as them as well, since they can't all be doing the same jobs simultaneously. If the craft is expected to regularly operate for more than half a day at a time, as the quarters, mess, etc., imply, there should be enough crew of all types to manage multiple watches/shifts, essentially at least doubling the crew overall. WW1 Zeppelins had crews between about 15-20 on average, and might be airborne for several days at a time, while the WW2 American B17 Flying Fortress bomber had a crew of ten and flew missions lasting about 6 hours or less, for instance, as very approximate equivalents.
The hatches on the hold deck are a bit confusing, and should be replaced with ladder symbols, I'd say, as the hatches are in the ceiling on that deck, not the floor, if I've understood the keys correctly.
How do the crew access the exterior of the ship, the balloons, or board and leave it? I see ladders up, but no doors in the upper outer surface, for instance, and no external doorways elsewhere.
If you're not wholly committed to the masts option, I'd suggest thinking of using the base of the balloon pods as places for magical propeller engines and individual rudders (again, see Zeppelins) instead.
Community Atlas: Errynor - Ellenge Town
As the ideas for undersea Kachayan settlements I'd been developing while working on the Shark Bridge maps were still fresh in mind, I decided to continue in that vein for the next Atlas map. In my original planning for the detailed maps from Errynor Map 01, I'd pencilled-in the largest Kachayan settlement, the city of Kelchayn in the northwest corner for further action. However, the way the Shark Bridge settlements had progressed turned my thoughts instead towards their Province's capital, Ellenge.
Having established earlier that Ellenge and Twin Peak Provinces had once been parts of the single, larger Kachayan Province of Twin Peaks, and that Ellenge had once been a city, now fallen on harder times, ideas began forming of a core of still-inhabited structures surrounded by disused to collapsed properties further from the centre. Then thoughts coalesced further, to the point of a major disaster or accident having destroyed part of the old city.
Revised semi-random systems from decades ago let me roll-up numbers of inhabitants for both the old city and still-extant town, which in turn allowed the number of structures involved to be determined. Additional random-table-creation and fresh dice-rolling devised lists of shops/businesses and community assets to be included. The appearance of a magical academy in the old city ruins from these provided a plausible candidate for the cause of the accident, an idea which was developed further before proceeding.
Since Kachayan sea-bed architecture concentrates heavily on domes, and wishing to continue the practice of using black-and-white mapping styles for these lightless deep sea settlements, I opted for the Cartographer's Annual package from April 2010, Black and White City Maps for this map, as it has a convenient selection of circular building symbols, originally meant as huts and tents, that would work just as well for domes. I knew already I was going to create the layout randomly using the Symbols In Area mechanism (no streets on the sea-bed!), so I drew a circle of appropriate size for the old city on my base map template, and populated it with the requisite number of domes/huts. I'd deliberately allowed some potential overlap of the symbols to let me identify where the larger final structures might be placed too.
Knowing in advance (for reasons I shan't disclose here!) that the worst-affected ruined area was to be towards the south and southeastern sides of the settlement, let me select a suitable number of domes for the surviving inhabited town away from this area. After that, it was simply a matter of going through the random map and deciding what building needed to go where from my pre-generated list. This also entailed changing some symbol sizes, and occasionally adjusting the shape by replacing those initially laid down with different symbols. Some symbols were also moved from their original placements, such as moving apart those "ordinary" domes that were still overlapping one another, and shifting others to help lose the "circular edge" effect because of the opening construction process.
Then it was time to show the area most affected by the magical accident across the southern city. I wanted this to look a bit unusual, not with a simple "radiating blast" form, but something odder and more organic - magical power flowing forcibly, rather than shooting, while also hinting at possible altered effects because of the deep-sea pressure. So I drew out a batch of spidery construction lines from the Magical Academy, and adjusted them a little, before replacing them with a spread of depressed channels, a polygon drawn using the style's normal river drawing tool.
The deserted/abandoned structures were easily demonstrated by moving them to their own Sheet, and applying a Transparency Effect to it, so those places still in use took on a sharper look by contrast, with darker lines and more marked shadows. The ruins proved more difficult. At first, I tried partially drawing over the normal dome symbols using aptly-shaded polygons, softened by Sheet Effects, to try to make them look as if they were partly silted-over. This didn't really work as I wanted, however, so I opted instead to replace each ruined structure with a broken outer wall line or lines, sometimes with "rubble" as well. Most of these ruins were merely circular rings fragmented using the Break command, with some pieces shifted away from their original spots slightly. Others were drawn polygons of appropriate form, tracing some of the lines of their original symbols, again using the Break tool to create holes in the walls, and fresh "rubble" to be moved from their preliminary spots. Having made the decision, this proceeded quite quickly.
Another problem cropped-up when I was trying to add a highlighting red Glow Effect around the edge of those still-occupied symbols that had an identified function. Other Effects already on the various SYMBOLS, DOMES Sheets interfered with this, and meant it wouldn't work correctly. An attempt by copying the affected symbols onto a new Sheet beneath their original, and applying the red Glow Effect only to that worked for the outlining nicely, but caused problems for the Blur and Shadow Effects on some, though oddly not all, of the Domes Sheets! This was finally resolved by drawing simple polygons or circles of identical shape and size to replace the symbols copied onto that lower "Glow" Sheet. I'm sure those more technically adept with CC3+ could have come up with a simpler, more elegant solution to this, though at least it worked for me!
After all this, adding the labels, scales, title and key for the still-occupied properties proceeded apace, using the CC3+ standard Mason Serif Alt Bold font. A pair of sunken-area old quarries for the city's building stone were added as well, and the surface map was complete:
Surface map? Well, yes. The magical "accident" fifty years ago or so that devastated the southern old city, including several major places there, seemed an ideal opportunity to create a somewhat paranoid ruling political structure for the current town. So while I'd always intended part of the city's buildings to be below the sea-bed, this became a more substantial undertaking, with a series of secret tunnels and subterranean places deep beneath the settlement. These can be seen in relation to the surface features by activating the SUBTERRANEAN Layer in the map:
By turning on the TUNNELS BACKGROUND (S) Sheet, the surface map is hidden, so just the underground system can be more clearly viewed:
The idea is both aspects can be accessed by toggles in the Atlas version of the FCW file.
Most properties at Ellenge, whether linked to the Secret Underground or not, also project some way below the sea-bed, typically no more than four or five "storeys", though in a fashion more like cellars on land. These are not illustrated on the map, however, much as they rarely are for ordinary surface city maps.
As usual, a PDF and text-file of notes accompanies the map, with additional descriptions and details on the city/town's general background, and for the labelled properties, with a list of those shops and other sites determined for, albeit no longer identifiable as such within, the deserted and ruined areas of the settlement.
Annual 1, issue 7 -Modern Caves map. My example after the Live Mapping session
This is looking a lot better to my eye, especially the trilithons.
Not sure about the rather bright Stone of Sacrifice now though, and those colourful small diamond shapes (leaves?) seem very "floaty" to me, as if they're suspended in mid-air somehow. It almost looks as if some are on a higher Sheet than the stones, but I think that may be an illusion because of the dark Tomb Outline that looks like a stronger shadow than any being cast by the surface stones. So I'm seeing that as being a shadow, and the "leaves" aren't being shaded by it, so must be "above" it. Not sure how that might best be resolved, or indeed if it's not just me...
Mushroom Symbols
If you can live with top-down view of mushrooms, there are plenty of options among the Dungeon Designer symbols for CC3+, and the add-ons for DD3 from various issues of the Cartographer's Annual. You should also check out the free downloadable Vintyri symbol collections as well.
If you want side-on views, that may be more difficult. However, Symbol Set 1 has a couple of options among its Handdrawn symbols, and there may be a few more elsewhere that I've not come across yet. You could also look at some of the styles with simpler tree drawings, and experiment with varicolor versions of those that look sufficiently mushroom-like. Might have to get creative though!
