2,970
Member
5,160
24
  • Most of my sheets won't show effects
    More importantly, have you managed to resolve the issue?
  • The Lost Vault of Tsathzar Rho
    @jmabbott asked:
    Is it possible to get a curved line with double arrows as in the original posted above?
    Yes. Rather than try to explain it, look-up "arrows" in the CC3+ HTML Help file using Search, and have it display the "Double Arrow" entry. For some reason typing "Double arrow" in the search bar comes up with nothing...
    You can add arrows at both end of a straight, arced or smooth path/line. As we've noted here before though, depending on what size of arrowhead you need, you may be better off drawing the line, adding filled polygon triangles for the arrowheads, and placing them separately yourself, as the automatic system can show the line extending beyond the arrowhead sometimes.
    jmabbott
  • Marine Dungeon - a Cartographer's Annual development thread
    As I've spent the last 18 months on and off mapping elements of the deep undersea (lightless, yet still intelligent-creature inhabited, parts of the Community Atlas world), I'll be very interested to see how this project develops.
    The biggest difficulty I found was the lack of prior examples to draw upon (it's a long-ignored topic even in fantasy RPGs for some reason), though for shallower, sunlit, seas, at least there are things like aerial imaging to draw upon, and there are established real-world mapping styles for the near-coastal seas too (like the Marine Maps CA style).
  • [WIP] Cliff City B&W
    That's much better!
    Still seeing some patches of pale grey in places, but that too might be a Sheet Effect. I have found that if you have a stack of objects on different Sheets above or very near one another, that can start to cause all kinds of weird problems, as the Effects seem to start interacting in completely unexpected ways - inexplicable, very often. Even two different Effects on the same Sheet can create oddities which then go away if you simply move one Effect above the other (sometimes)!
    Symbol gaps can be tricky to overcome in these cliffs. You may resolve some by simply adding a few short hand-drawn lines of suitable colour and thickness in the appropriate places. Where you have sets of lines forming a "V" shape, you could add either hand-drawn lines or extra, more broken, cliff-lines, to suggest hanging valleys on the cliff-tops, perhaps.
    JulianDracos
    This is looking much better for the "mesas" in the central area. The long cliff line at the northern edge shows one problem, in that the cliff lines on that aren't shaded at all, which really detracts from losing that "floating" impression.
    There seem to be a number of pale grey polygons in places, which are rather distracting now. If these are needed (I have the impression a couple may be being used to conceal unwanted parts of the shadows in places), I'd suggest changing them to match the background colour.
    The "white gap" event may be due to some of the Sheet Effects interfering with one another. If it persists, and you can't find the cause, you could try uploading the FCW file here for one of our more technical experts to examine, as I'm sure they could find a solution to that sort of problem if necessary. It may be there's something else on that upper cliffs Sheet that shouldn't be there (a white polygon, perhaps), and that's all that needs resolving.
    Shorter shadows just mean a higher Sun, so hopefully this won't be too much of a problem in terms of still giving a useful impression of height for you.
    JulianDracos
