- Wyvern
- 3,239
- Member
- 5,519
- 24
WIP: Kariss, Isle of the Purple Towns
Winter Village style development (March 2022 CA issue)
Having lived only in places with tile or slate roofs, I can confirm Shessar's photos are indeed entirely accurate for both those materials. Slide, wind effects and thin ice/snow melt basically works from the top down, and outer roof edges facing more nearly into the current wind, so those will all tend to clear of snow first. This can be enhanced around objects sticking out of the roof like chimneys and stove pipes, especially where those are in use. There may also be some smoke discoloration of the snow near chimneys that are in heavy, regular use as well (albeit that also tends to mean snow there will melt faster as well - introducing foreign particulates to the ice/snow helps it melt faster generally, like applying salt to road and path ice).
Roof patches do tend to be harder edged than you've illustrated so far, and with a tendency to remain in the hollows a little longer than the ridges on shaped tiles, as you've already noted. There are a lot of variables however, and commonly, once the snow's started to melt on such roofs, it will tend to clear fairly quickly thereafter, unless there's fresh snowfall heavy enough to fill-in the cleared gaps.
Snowy roofs looking good now; perhaps not so "realistic" in the strict sense, but we already discussed that above, and they do look the part to me.
Not so sure about the pentagonal igloos (and yes I know they're actually the detached add-on dormers window roofs!) 😉
[Although they would actually work quite nicely as sheds/small huts partly buried in snow drifts too, more seriously.]
Live Mapping: Star Systems
There are things to be said for both options (plus of course, you can't assume everyone will wish to map somewhere where the snow falls in late autumn/early winter, thickens and only starts to thaw around the start of spring - i.e. the randomness of what happens in British winters!), and both are obviously buildings. However, the one with less snow cover has a bit more character to it, which would definitely support the idea you mentioned in your most recent post Sue.
