3,153
Member
5,382
24
  • WIP tavern
    While the size may seem wrong, by a strict comparison with some medieval European structures, this isn't for medieval Europe, it's for fantasy D&D, and is close to the scale size for this specific tavern as shown on Mike Schley's map of Saltmarsh in the Ghosts of Saltmarsh scenario book (Wizards of the Coast, 2019), assuming five-foot grid squares here. The appearance isn't quite the same as on that map, but this is an adaptation after all, and although there are a number of designs for the Wicker Goat Tavern online, I don't think there's an official D&D version, so some leeway is to be expected.
    In the original adventure (The Sinister Secret of Saltmarsh, TSR's Module U1, from 1981), you were expected to create your own version of the town from scratch - there are a few guidelines for key points, such as Point 4: "Decide where the characters could stay when resting in the town between adventures (the best inn? the only inn?); draw up a tariff (list of expenditures) for their accommodation and food." But that's as close as we got to a description for the inn/tavern, which didn't even get a name back then!
    That's not to say such points should just be ignored necessarily, and the heating and access points are useful considerations. However, if the final tavern is meant to fit to the size of the official Saltmarsh map, this is close enough to work for that.
    ShessarDak
  • Panzer sample thread
    +1 from me for the tanks/AFV annual!
    If you're seriously thinking of a full range of vehicles, maybe choose a specific theatre and time to reduce the options somewhat. Colour schemes and camouflage will easily swap over, but the modifications to vehicles, and the different types involved, end up as the real problems (speaking as a long-time model-maker and WWII wargamer).
    Aircraft to follow? 😉
    LillhansJimPLizzy_MaracujaOctorilla
  • How to correctly create linked maps?
    See this blog article by resident CC3+ expert Remy Monsen. Hopefully, that should help, but if you get stuck, feel free to ask here again!
    LoopysueScottA
  • Community Atlas: Errynor Map 40 - Faerie Land
    As mentioned recently in another Forum topic, the next of my 40 250 x 200 mile maps detailing the Errynor area of NW Alarius on Nibirum is now ready for submission to the Community Atlas. Despite becoming "distracted" into preparing more additional maps for the first Errynor map than I'd expected initially, Map 01 - The Cliff, I decided to continue with the next one in the order I'd originally intended, by switching right across the map to its opposite, lower right, corner:
    Beyond that though, much of the pattern for the mapping - using the Herwin Wielink style, some Cartographer's Annual 62 Geometry varicolor symbols, the Cagliostro (from the 2017 CA), Candara and Gabriola fonts, the latter both from standard Win 10 installations - had been set already by Map 01. There were though some differences. This time, I'd be mapping the most landlocked area in Errynor, not one that was almost entirely under the sea. While that simplified the number of different map views I'd need to create, because - clue in the title "Faerie Land" - I wanted to illustrate the effects of the two overlapping realms, the Mortal one and that of Faerie, it didn't reduce them to zero.
    The initial layout was fairly straightforward, and largely involved hand-copying the details from the Errynor map area above into the template for this new map, with additional items from the hand-drawn original as discussed in the "Construction" topic. There things rather stalled though, as I realised I needed to work out details on what the Faerie influence areas were going to look like and exactly where they were going to be. Plus I also suddenly had lots of features that clearly would benefit from being named.
    The Faerie areas were relatively easily worked out by simply hand sketching some ideas on a tracing-paper overlay to the original squared-paper map, and I already had some feature names from my decades-long work with earlier versions of Errynor that could be reused.
    However, you know me and my fondness for random design mechanisms... One of the early Judges Guild printed works I got was their "Village Book 1" tome, from 1978, and in that is a system for generating random village names. Up to 368,000 of them! The names will work perfectly well for other sorts of places too, with the addition of terms such as "Wood", "Forest", "Marsh", "River", "Brook", etc. So I rolled up a long list of possible names. Each series of rolls generates a two-part name, prefix and suffix, effectively, though you can add more parts to vary things from time to time too. Not every combination works well, as you might imagine, but the names can be subtly altered, or only one part used, or merely used as inspiration. I was pleasantly surprised to find most were actually very suitable for what I wanted; some that seemed obvious, some a little odd, some that could be humorous, some a warning, many intriguingly evocative, much like looking at a map of real-world places in fact. So here we have Map 40, complete with place names:
    And a close-up of just the NE corner to show a bit better detail at the usual Forum resolution:
    If all goes to plan, there should be a toggle in the Atlas FCW version to allow access to the latitude lines, and an arc indicating the southern limit of Nibirum's polar auroral zone, too:
    That slightly offset-from-the-corner compass rose is to allow for the numerous creature markers and labels in that corner, as elsewhere across the map, to be shown (again, another Atlas version toggle is intended to allow these to be displayed or hidden):
    Which looks rather messy at this resolution, so another close-up may help, this time over in the NW map corner:
    Plus of course, there needs to be a map key as well:
    The areas where the Faerie realm overlaps most strongly with that of the Mortal plane can be shown via a further pair of toggles to indicate the core areas, and the maximum extent of the overlap on a few special nights each year. The following images are of those whole-map core areas and a close-up of the separated patches west of the great Faerie Run river, followed by the line of the maximum Faerie overlap extent:
    These can be shown combined with any of the other toggleable map overlays, and for anyone concerned at the lack of a scale, that's because to try to improve the resolution, I've shown just the map rectangle here till now. This is how the map really looks:
    The complete layout is then this:
    The Atlas will also have a 23-page PDF, and a text version, with its accompanying detailed notes, explaining a little more about the settlements and the significance of some of the creatures and resources.
    I haven't quite finished with Map 40 yet either, as the River Clack valley with the great Faerie city of Embra (see the first of the detail maps above, the NE corner one, for these locations) is to receive some further mapping in the Atlas shortly too.
    [Deleted User]LoopysueScottADaltonSpenceMonsenJimPAleDRickoRalf
  • Live Mapping: Shaded Contours (Annual Vol 2)
    Forgot to post this after the livestream. I know there was some further discussion about Bevel Effect problems and the changing appearance of the Bevel at different zoom levels in the chat during the stream, some of which Ralf touched upon in the video. I'm not sure if anything was resolved later in this regard (I know sometimes these discussions move to the FaceBook page, which I don't use).
    I wanted to add that if you have the CA169 Fantasy Town Annual from 2021 January, there are hill and contour drawing tools in that which use the dark Solid bitmap fills and the Bevel Effect to generate hills. While you could of course create your own drawing tool in any style similarly to test out, these do come ready to use as part of that package. I've been mapping a lot with this style in recent months, and it has been interesting to experiment with the hill tools, to see just what drawing different shapes can generate, including what seem to be flattened, or even indented (so crater-like) hilltops sometimes.
    This probably doesn't help move forward the bevel-zoom issues, but it might help those wanting to try things like the shaded relief techniques get a better feeling for what is possible using the Solid fills and the Bevel Effect.
