3,237
Member
5,515
24
  • Community Atlas: Barrows of the Ferine Magi area, Feralwood Forest, Alarius
    Thanks very much Remy. And apologies for sending yet another batch of new maps to you for the Atlas yesterday... Still, this way we get to watch the Atlas grow and grow!
    Ricko
  • CC4 Overland Development Thread
    Sue commented: Don't forget this is just a first draft. There may be many different versions.
    That's a shame; I kinda want a complete style with this look now ๐Ÿ˜‰๐Ÿ˜! Could be a lot of new Annual issues in it, Sue ๐Ÿ˜Ž!
  • Ricko's Questions
    Too late to be of much use now, I realise. However, dashed lines, even when you've adjusted the settings to give suitable lines and spaces, often need minor tweaks after drawing them, as has been mentioned already. As Sue said, simply adjusting one node on the line by a few pixels is often enough to stop the unwanted "looong" line segment, or occasionally removing one node, although I find the line adjustment method is more reliable, and easier to correct. Of course, you have to check the whole line, because correcting one spot may create problems elsewhere. So again, I often draw any lines like this in shorter stretches, to keep such difficulties within manageable limits.
    The problem seems to be commoner when you have a couple of nodes quite close together in one part of the line, so again as Sue suggested, keeping the number of nodes overall as low as practical, will likely help. (Except when it doesn't, of course ๐Ÿ˜‰!)
    LoopysueRickoDon Anderson Jr.
  • City on the Coast
    Dak noted: In my campaign atm there are two major cities and there have been mumblings of going to one of them, so I thought I'd best do a map.
    Well, if that isn't the catalyst to have them go visit the OTHER city, I don't know what is ๐Ÿ˜‰!
    Dak
  • [WIP] The Old San Francisco Mint (Dracula Dossier)
    Have to say when I first looked at the floorplans, I wondered why they'd built a mint with no real security - all those walls with massive holes through them! But then I looked a bit closer and realised they were actually windows ๐Ÿ˜!
    Don Anderson Jr.Royal Scribe
