- Wyvern
- 3,151
- Member
- 5,378
- 24
Community Atlas: Barrows of the Ferine Magi area, Feralwood Forest, Alarius
CC4 Overland Development Thread
Ricko's Questions
Too late to be of much use now, I realise. However, dashed lines, even when you've adjusted the settings to give suitable lines and spaces, often need minor tweaks after drawing them, as has been mentioned already. As Sue said, simply adjusting one node on the line by a few pixels is often enough to stop the unwanted "looong" line segment, or occasionally removing one node, although I find the line adjustment method is more reliable, and easier to correct. Of course, you have to check the whole line, because correcting one spot may create problems elsewhere. So again, I often draw any lines like this in shorter stretches, to keep such difficulties within manageable limits.
The problem seems to be commoner when you have a couple of nodes quite close together in one part of the line, so again as Sue suggested, keeping the number of nodes overall as low as practical, will likely help. (Except when it doesn't, of course ๐!)
City on the Coast
[WIP] The Old San Francisco Mint (Dracula Dossier)
