3,237
Member
5,515
24
  • Printing maps from PDF?
    So far as I understand it, if you have an MS Office 365 sub, Publisher will cease working in October this year (I think - can't actually recall the exact date now). If you have Publisher on a computer that isn't connected to the Internet (so it was purchased years ago, probably on a disk of some kind - 3.5" floppy or CD-ROM), you should be fine.
    I checked around earlier this year when this was first announced, and it seems that the free Libre Office suite (essentially the free equivalent to MS Office) will still open MS Publisher files. I haven't had time to install and check this as yet, but I know the earlier version of their MS Word-equivalent worked fine, and would open MS Word documents, although MS Word (of course...) won't open their files.
    I like Publisher because it's so easy to resize the physical page size to fit whatever you're creating exactly - so it's really easy to create and save images, including images drawn in Publisher, to a very precise size. I know you can do this in other programs as well, but I've been using Publisher for decades, so it's much easier that way. I used to create all my maps and diagrams using it 20+ years ago, including for print publications!
    Royal ScribeDon Anderson Jr.Loopysue
  • [REQUEST] Can we PLEASE get Warhammer Fantasy Resources!!! ^_^
    GW are not noted for their generous licensing terms; very much the reverse, in fact, judging by conversations I've had with owners of small businesses interested in trying to sell their physical products over the years, and they insist on a huge amount of control over exactly what can be sold, how much stock the business HAS to take per month (regardless of what the business itself knows will actually sell), and how it can be displayed. I can't imagine they'd be any more willing to consider something like this. If they were interested, I'd expect they'd be doing it in-house already.
    ScottALoopysueRyan Thomas
  • Interesting Political Take on the Mercator Projection
    Interesting broader discussion here. The earliest surviving topographical (known-)world maps tend to show the map creator's country/city in the centre, and many are circular around that point. Wikipedia's Early World Maps page has some useful illustrations in this regard. While that may have had a political motive, there's also an eminently practical one, because then you're able to draw the world moving out from where you started.
    Into the medieval period, European maps often had the eastern end of the Mediterranean as their central point, because of its significance for the dominant Christian religion there at the time, and were drawn as circles or ovals out from that area.
    If the region around your home site ends up larger and more detailed, that's at least as likely because you'll have more, and far better, information about that area than any other, which you might visit - if at all - maybe once in a lifetime for a few hours to days, in ancient to medieval times. So there doesn't always need to have been a political-patron motive there, significant though that undoubtedly was for some early cartographers.
    Maps for planning intercontinental aircraft journeys are still prepared with the originating airport at the centre, and extend out in a circle from there, for instance, to allow the selection of the great-circle line required to reach the destination in the minimum of time, using the least fuel possible.
  • WIP - Wayward Village and Inn
    Glitch commented: 2. Use the select point option to draw grid box. Easy to do, but if you have and irregular building, setting two grid boxes creates a misalignment of the two grids.
    It shouldn't create a misalignment if you use the snap grid properly, but you may need to mask the second grid in places. Or you could just draw one grid across all, and mask those areas of the grid that lie beyond the structure's walls.
    As with most things in CC3+, there isn't just one option for solving issues like this - it's which one you're more comfortable with that typically wins the day.
    Don Anderson Jr.Glitch
  • Hex Crawl Test
    Economic and wildlife symbols often get left out - and even when the overland styles do include some, they can be quite selective. They're often useful, and more helpful for GMs than simpler dot-type place-markers.
    Ruins, and different types of ruin (so you could build up to a ruined city, say). Could include giant statues (like the Sphinx or the Colossus of Rhodes).
    Ships, sea monsters, reefs, whirlpools, etc., to decorate the oceans.
    Flat-topped mountains (like mesas), volcanoes, lava flows, glaciers.
    A few ideas only, but maybe something to spark some further thoughts from yourself, or others here?
    C.C. Charron
