3,238
Member
5,515
24
  • HomeBrew World of Andaar by F.W.Whited Drawn By D.A.McDowell CC3+
    Where is this barony on your main map? That might give us a better idea of what to suggest regarding the vegetation cover shown on it.
    If the whole area of the map is heavily wooded, you may be right to suggest you don't really need trees on it at all, but if there are notable clearings, or areas of more open woods, some means of indicating where those are would be necessary. Plus I think you may have taken away the marshy area southeast of Loch Lomond along with the trees, and the other green background colours.
    If you need help adjusting the parameters for your road lines, Remy Monsen's live mapping session Modern Streets with SS3 showed how to do this, starting at about 32 minutes in.
    Quayuazue
  • Finding Joe Sweeney's CC3+ videos
    During some discussions on another Forum in the last couple of days regarding options for computerised mapping, the subject of Joe Sweeney's excellent videos for CC3 came up, and I made the point about them being for CC3, not CC3+, which has come up here repeatedly, even relatively recently.
    Then another commentator said there was actually a whole series for CC3+, posted about three years ago. And when I checked, lo and behold, yes there IS indeed an entire set for CC3+, overland mapping, and another set for city mapping with CD3 added a year ago.
    They're all on this YouTube page, with the first overland video here.
    However, the ProFantasy tutorials page still links just to the older CC3 videos. I don't think there are any newer dungeon/battlemap video tutorials, certainly, but the links maybe need updating now for the CC3+ tutorials (and perhaps also the zipped download set needs changing?).
    I think the newer videos have come up on the Forum before, because I'm sure I watched the overland series for CC3+, but I tend to use the PF tutorials page when I'm quickly trying to find links to pass to someone else, and I know the last time I checked the link for Joe Sweeney's videos I had saved separately, the CC3+ videos DIDN'T appear on whatever that link went to.
    Maidhc O CasainLoopysuejmabbott
  • Ruins
    The wall drawing tools in DD3 are usually lines of varying thicknesses, I think, which makes it harder to disguise their pristine nature without some extra work - adding rubble symbols, for instance, and maybe trying some additional Sheet Effects on them (as well as Monsen's Color Key suggestion), to give a more "worn" appearance.
    Loopysue's suggestion is a good one too - using symbols to make the walls in the first place is a definite alternative. There's the Dungeon Walls Annual issue from 2018 which uses exactly this technique, for example.
    Or you could try drawing the walls using polygons instead of lines. That way, you can give any breaks a more ragged appearance as you're drawing them, and even vary the thickness of the wall itself. That will probably need some symbols adding to improve the effect though. Ruins just aren't designed for neat-edged drawing tools!
    There is an Annual issue from 2014, the Black & White Battlemaps one, which has a few ruined building symbols in it as well, though they're intended for larger-area overview maps than the usual dungeon maps - plus, black & white only, of course.
    I've probably forgotten others too ?
    JoeyD473
