- Wyvern
- 3,238
- Member
- 5,516
- 24
Will there be an October Newsletter?
I wasn't really suggesting it was the fault of the English; just commenting on how many different nationalities had decided to call the tenth month "the eighth" 😉
In fact, it goes back way before the Christian Church, to the ancient Romans in the first millennium BCE, and survived as a month name even after the Julian calendar reforms of 46 BCE shifted it to being the tenth, not the eighth, month (by the Julius that was Caesar - hence also "July"), and on to today.
Well...
So far as I recall, the earliest record of the Christmas tree is from the 1520s CE Rhineland, which was of course firmly Christian at the time. There were earlier records of different, much smaller, forms of green vegetation, up to small branch size, being taken to, or into, homes around the Christmas/northern winter solstice period in various parts of Europe long before this, including back into the first millennium BCE. However, this seems to have been a common theme for pagan celebrations at many other times of year as well. Setting Christmas as Dec 25 is definitely recorded only from 354 CE at Rome though. The date was chosen (in preference to others at the time and before, which were usually sometime in the northern spring) apparently because there was indeed a pagan solstice festival for the Roman Sun God on the same date, albeit that was decreed only in 274 CE, and seemingly wasn't a particularly major event. The pagans overall were rather more "distracted" by whatever was the current Roman Emperor's preferred choice of deity. (Pretty much what happened in Britain too during Tudor and Stuart times, but with Protestant or Catholic Church beliefs holding sway, for instance.)
Eggs were one of the foods prohibited by the medieval Christian Church during Lent, in the six weeks before Easter, and while eggs were long a popular symbol of new life and spring-time in general, their attachment to Easter (in various subsequent forms) seems to have come about simply through the Christian Lenten prohibition, rather than because of any pre-existing pagan significance associated with the Easter festival time (mobile anyway, as Easter was and is tied to the timing of the first full Moon after the northern vernal equinox). Eggs were a regular delicacy for those unable to afford meat (i.e. most of the population in Europe) in medieval times, for instance.
[All a bit fresh in mind, as I was looking into European calendar customs in some detail recently, part of something for my latest Community Atlas mapping.]
Just as well this thread was answered a while back, as I've thoroughly hijacked it now - sorry!
CA style development - "Darklands City" (issues for September and December 2021)
@JulianDracos noted: ...I am interested in Hobbit house symbols. I have found a way/map style that I can do OK to demonstrate it is a Hobbit style home city, but I do not have anything for the city level view.
SS5 Cities of Schley has a selection of Halfling house options (grassy mounds with round doors and windows), and also Elven treehouses, plus rough-looking Orc buildings. The main CD3 Bitmap B style has a larger range of fantasy building options as well, including for Halflings (houses and grassy mounds) and Elven treehouses again, as do the main CD3 vector styles, so there are options there without needing to go down the Annuals route. And the Annuals, being smaller in size than these main products, do tend to concentrate more on providing the basic styles first.
It is worth noting that you can draw your own house shapes using the CD3 toolset, and give the roofs whatever texture you wish from the range of options you have available. Stacking different shapes on top of one another on different Sheets with variant Effects can also increase the options for how things appear. DIY treehouses by placing a suitably-shaped and textured house in different sized tree and other vegetation symbols, all on separate Sheets, for instance. And things like varicolor wooden roofs can be made to work as market stall awnings with a bit of resizing and choice of suitable colours.
Sorry for hijacking your thread, Sue! Can't really add much beyond what's already been suggested above for Darklands Cities II, after all that... 😪
Live Mapping: Modern Blueprints
@Loopysue - It's a good video for maps where you have one or more scaled items in the part of the image you intend to use.
If there isn't something like that in the piece of map you want to copy, it's worth taking some extra time to construct an image that does have the correct scale in it - which will likely mean extracting and adding the scale into the map image in image processing software before importing it into CC3+. Key element is to ensure the two bits of the image don't get accidentally rescaled compared to one another before making the final PNG or JPG...
And also not to mistakenly cover some essential bit of the map with the scale...
Addon/Mappack for lava-worlds?
DD3 has four different bitmap fill lava textures, Stone Lava Cooled, Stone Lava Flaming, Stone Lava Molten, and Lava. The Jon Roberts Annual Dungeon style has three, Lava, Lava Hot and Lava Cool. The Munson's Mines Annual Dungeon style has three different reddish lava bitmap fills. The Vandel Dwarves Annual Dungeon style has two reddish lava texture fills similarly. The Mike Schley Annual Dungeon style has a single lava bitmap fill. The Naomi VanDoren Annual Dungeon style has three, Lava Hot, Warm and Cool. SS2 Bitmap A has one lava bitmap fill, and the Bitmap B style has one more. Those are what I found quickly, anyway, among the full-colour dungeon styles. It's also worth looking at the various stone textures in the same style pack as the lava fills, as some could be used as cooled lava too - or changed up to something hotter using some of the colour-changing Effects options, perhaps.
Suggestions for Variable River Size
@JulianDracos asked: "Another question is how do I chop a river?"
Ralf demonstrated exactly this, and the method to increase a river's size on an overland map, using the Pete Fenlon style, a couple of weeks ago on the YouTube live mapping stream. It starts around 19 minutes in here.
