- Wyvern
- 3,238
- Member
- 5,517
- 24
Using Watabou generators to creat a campaign.
How to correctly create linked maps?
See this blog article by resident CC3+ expert Remy Monsen. Hopefully, that should help, but if you get stuck, feel free to ask here again!
Searching for symbols for WW2 and modern military vehicles, artillery etc.
If what you're wanting to do is use online images to make your own vehicle trace-drawings for conversion to symbols, it's worth checking the military museum sites (especially if you're hunting for more obscure vehicles) and also scale model websites - including model kit manufacturers. A number of manufacturers now have PDFs of their kit instructions online that you can freely download, and they sometimes have illustrations showing top-down views for the paint and decal schemes for instance, which might be another starting point.
In terms of constructing the symbols, I'd suggest having a set-up where the lines, base colour, camouflage patterning and any markings are each done as a separate Sheet in CC3+ (or more likely "layers" in non-CC3 graphics programs), to make it easier to swap those for different theatres and times. Also, @Lillhans' comment about separate tank turrets is an excellent one. I'd suggest too using Sheet overlays for the top of various AFVs that have different variants using the same lower chassis and skirts, again to make those easier to swap-out without having to keep redrawing each time.
Searching for Farmland
Simplest option would be to use the colour drawing tool, and then add an RGB Matrix Process Effect to the whole map, set to "Gray". This will make everything look B&W - so you could design the entire map using the colour set-up, and have it all appear as greyscale in the finished item.
In case you're unsure about adding the Effect, when you open up the Drawing Sheets and Effects dialogue box (click on the rectangle marked "S:" with the name of the current Sheet in at the top of your CC3+ drawing window), click on any Sheet, then click the "Whole Drawing" radio button above the Sheets list.
Then click "Add", select "RGB Matrix Process" from the list this will call-up, and then click to highlight the RGB Matrix Process Effect that's now been added to the Whole Drawing list.
Then click "Edit". Once you're in the RGB Matrix Process dialogue box, click "Predefined", then "Gray" from that list, and finally "OK", and then (assuming you have something already drawn on your map to check), click "Apply" to see what it does.
Good luck!
Connecting Symbols
If all you want to do is place individual symbols from one of the City Cliffs Cartographer's Annual sets, select your first symbol choice, then right click to call up the Symbol Parameters dialogue box. Once there, uncheck the "Smart tracking" box and check the "Disable smart symbols" box. Then you can just pick and add whichever of the cliff symbols you want to your map without them connecting to one another as they ordinarily do.
