3,238
Member
5,516
24
  • Switching symbol orientation - Symbol Set 6
    The Arena symbol only has one orientation, but the Amphitheatres tab fine for me.
    Mythal82
  • Issues with Inked Ruins Style: Hatching "Texture" Size and Water Rendering
    You're very welcome Eukalyptus! Glad it helped.
    Turning off the "Restrict to map border" command was one of the first things I discovered, because it solves so many problems with the effects, such as when you've applied something like an edge fade (or other similar techniques) to a fill, to avoid getting those round the map border too, creating a border within the border, which almost always looks wrong. When I remember now, I usually turn it off in all tools I know I'll be using, because it's just so annoying sometimes. I understand why it's turned on as the default, although for someone who often works outside the technical map border - to add map keys, for instance - aside from with on-map features that don't benefit from a sharp map-border edge - it's a real pain. Appreciate I may not be typical in this though 😊!
    JulianDracos
    The water lines problem looks to be one of the classic issues with too many nodes too close together, in this case because the water drawing tool is set to not extend beyond the map border, and as a smooth drawing tool, it will automatically put a pair of "Corners" at the map border to create the straight line there. A Corner is basically three nodes very close together.
    A quick check suggests you should be able to solve this by using the "Advanced" button for the water drawing tool, unchecking the "Restrict to map border" box and then save the tool. Then redraw your river, making sure you draw the ends a little way beyond the top and bottom map edges. DO NOT use the "C" = "Corner" option, just add a few nodes and make the ends of the river outside the map border a bit more rounded, with fewer nodes close together. The screen should hide this once you're done (or if not you can use the COLLAR commands to create a new, larger one - use COLLARDEL first to remove the existing screen, and then COLLARAUTO to add a new one - if I've remembered that right).
    Hopefully, that'll cure this point at least. Good luck!
    LoopysueJimPQuentenEukalyptusNow
  • Wall Mural Symbol
    This blog posting by Remy Monsen might be worth reviewing, as it will allow you to create an image of whatever you wish that looks as if it's been cut into the surface involved.
    JulianDracosLoopysueJimP
  • Galangar - The City of Gold and Red
    Looks good.
    Obviously, the Empire of the Sun Annual would work nicely for a map of this kind, based on your sketched style, but that wouldn't provide nearly so many building/structure options. For clouds, you might try the cloud symbols in the Alyssa Faden Annual. I'm not sure there are other separate cloud symbol options, although SS6 does have some chimney smoke plumes (they look a bit too smoke-plume specific to be ordinary clouds, however, unsurprisingly!).
    Might be worth thinking of moving the mountains further back overall, as they don't look quite right where they are now; too sharp and clear. Maybe add a misty vale in between the building and mountains/trees, and/or just add some mist (transparent irregular polygons of white/pale grey) to fade them a little, and give the impression they're more distant.
    EukalyptusNow
