3,238
Member
5,515
24
  • a prototype under ground home for a dragon and some questions
    It's always as well to remember to check the information lines on the CC3+ page when you have a symbol ready to place, to be sure which sheet and layer it'll be placed on. You can always change those before or after you place it, though if afterwards, remember to do so! I usually forget to check the layer, as this doesn't always change automatically with symbols...
    Also, when selecting anything, always keep an eye on the Command Line (lower left screen corner of the CC3+ window), just to make sure you haven't selected two things when you only wanted one. That's saved me any number of times, certainly.
    So far as I can tell, there's nothing actually on the MAP BORDER sheet currently (apart from the usual automatically-generated pin items that retain a sheet in the map file).
    The brown frame for the map is on the cave floor1 sheet, however, as is the brown piece of flooring on the right side of the map, and I think this may be the problem. There is nothing else on that sheet, however.
    Hide all the sheets except cave floor1. That way you can move the brown frame to the MAP BORDER sheet, which will leave the patch of brown floor on cave floor1.
  • CC3+ Update Can't Find FCW32.mac File
    Not sure if you've seen this FAQ post by Monsen Scott, but it may help.
    ScottALoopysue
  • Sticky Note Dreamlands - An Experiment
    Thinking more about the new Sticky Note Dungeon Annual just released yesterday, while checking it over and afterwards, it occurred to me that with a few additions, it could be used equally to generate a form of point-crawl overland map too. For those unfamiliar, this is a sketch that links places of interest in a pattern to identify how the various points can be reached, without bothering too much about the exact distances, directions or terrains intervening - except that things such as intervening difficult terrain might mean no direct links, with instead a set of further points bypassing the blocking feature to be encountered along the way.
    As an example, I created this map almost ten years ago now for a wargaming magazine article on Jason and the Argonauts, showing a stylized series of overland connections along the western and northern Black Sea shores of Anatolia, into about the middle of that great peninsula, and along the coast north to modern Georgia, ancient Colchis:
    This isn't all that clear at the usual Forum resolution, so I've added a further version at higher-res to my Gallery.
    Thus essentially what can be drawn for such a system is a very simplified map, one that here even ignores the coast, and features only the main river lines of significance, chiefly those that cross travel routes, all in a rather abstract manner.
    Something that's long been of interest to me has been trying to map the places referred to in H. P. Lovecraft's stories concerning his Dreamlands. I've had a couple of tries at this myself, the first time almost 40 years ago, and another that sadly didn't get very far more recently, using the beautiful E Prybylski Watercolour style from last year's Annual. Several other vastly superior to me artists have created their own versions of such a map over the years too, which all have their pros and cons.
    One main difficulty is the details in Lovecraft's tales don't include things such as specific distances, or where different places might lie in relation to those mentioned in one story, and perhaps only obliquely referred to in another. Distances might be given in terms of hours or days sailed or flown on sea or in the air, or overland by yak, zebra or on foot, or might just be stated as being a long way apart. It's possible to estimate real distances by making assumptions, but this still doesn't help in locating where some of the places mentioned, but not passed through, or directly connected to elsewhere, were.
    In the stories, as it would in genuine dreams, this all makes perfect sense, since these aren't real places, and Lovecraft was a lifetime lucid dreamer, so was writing more or less from experience. As a mapper though, it quickly becomes problematic.
    However, the Sticky Note concept helps here, by generating a means to show places with some details about them, and lines showing how they connect, without worrying about details on exact directions, distances or even the size of a given place.
    So I tried a quick version as a test earlier today. Had to create a couple of new drawing tools, and import a bunch of symbols from the SS1 Handrawn Hollow set, but it was all pretty straightforward. I drew out just the places along the Southern Sea coast, heading westwards from the great city of Dylath-Leen, as described by Lovecraft, using an annotated hand-sketch I'd prepared last year when working on the E Prybylski version:
    Obviously, a lot more could be done than I've tried here, and this is a bit rough-and-ready in places, but the basic concept seems sound.
    These SS1 hand-drawn symbols seem to work quite nicely, although I'm sure none of us would be averse to having a purpose-made set in the C. C. Charon style, should an overland version of the Sticky Note style be offered subsequently ๐Ÿ˜!
    (We might need an A3 or larger option for the paper to draw world-sized maps though ๐Ÿ˜‰)
    Royal ScribeLoopysueMaidhc O CasainMapjunkieC.C. CharronRalf
  • WIP Community Atlas - Mortyn-Goya Confluence
    If you're stumped for ideas of what to place and where on a map, I'd suggest trying out some dice rolls on a few random overland design or encounter tables, if you have any. Even if you don't like what they come up with, that might spark ideas you do prefer - or variants on those themes.
    As I have the book sitting by me as I type this, have six random throws from the Shadowdark RPG overland generator tables:
    • A natural landmark controlled by a malevolent sorcerer.
    • A village occupied by a self-titled king.
    • Barrow mounds guarded by their current residents.
    • An abandoned, ruined, fortified keep.
    • A town connected to a large tomb.
    • A cave formation that's home to a religious cult.
    Make of those what you will!
    There are hosts of free-access tables online, often on blogs, although many are for rolling encounters, rather than places. Even so, you can still glean ideas from those. I came up with these three, of perhaps variable utility here, on a quick search just now:
    100 Overland Descriptors by Gnome Stew
    1d100 Random Events for Overland Traveling from Lore Wise Games
    The Collaborative Gamer's System for Creating Fantasy Adventures
    The last one has a whole series of tables, many of which won't be of much use here, but some of the later ones are readily adaptable for ideas such as you're asking for.
    Good luck!
    Shessar
