- Wyvern
- 3,238
- Member
- 5,515
- 24
Can't Export this to JPEG
It's just a thought, but at this large-scale of map, you can use the straight drawing tool and get a nearly identical "natural" appearance, simply by clicking more nodes as you go along. Although this obviously creates more nodes, they'll end up as a mere fraction of what you'd get by always drawing using the fractal tools, which often add far too many nodes on their default settings. You'll also end up with a map that looks pretty well identical to this, but one that you'll have more control over in all manner of ways.
I've found CC3+ will crash (shuts down) without telling you why if you've set the export to a size your system (or the combined your + CC3+ system) can't handle. Occasionally, you might get an error box telling you something similar before this happens, but not always. Typically, I find setting the antialiasing to zero, or just turning it off, will solve the problem. However, it may be there's something else at work in this case too, of course.
How can I make my grid overlay black on some backgrounds and white on others?
You may find too that increasing the line thickness of the grid may help, regardless of what colour you choose for it. The automatic grid creates zero-width lines, which can simply vanish at some image output resolutions.
You also don't have to create a single grid across the entire map. As long as you use the same snap grid point to start your grid's placement, you can have several smaller grids wherever you choose, and they'll all line up OK. That way, you can have different coloured grids on the same sheet (though of course, that may not work for all, dependent on what effects you have on that sheet). Or you can set them up on different sheets to get different effects per grid colour.
Live Mapping: Sticky Note Dungeon
Might be worth mentioning too that we found a minor glitch with the Sticky Note Dungeon Regular font, which has also been updated in the Annual download now. However, being a font, you usually can't just overwrite this on a Windows system, so you may need to remove the original font first (it should be in the Windows - Windows - Fonts subfolder) before you reinstall.
If you have already done a fresh reinstall though, just remove the font then do a repair reinstall using the Sticky Note Dungeon EXE file, and that should sort it (I have done just this as a check!).
