Shessar
Shessar
- Shessar
- 202
- Member
- 590
- Mapmaker
- 9
Reactions
1000th Map Competition: Ober, Southern Scar
Community Atlas 1000th map Competition - with Prizes [August/September]
Need some help fixing an old map
Hello! I've converted many, many maps from CC2 to CC3 over the years. It can be tricky at times. Here's how to fix this one....
- Open Symbols>Symbol Manager
- Scroll down and click to select the Room Circle 1' symbol.
- Click on edit then draw a bounding box across your screen. This opens the symbol in the editor.
- Now Select Send to Back on the right hand button bar.
- Right click within the editor window and select layer
- Choose the walls layer, click OK, then Do it.
- Close the editing window via the x to close and say yes to save.
You should be good to go. Give a shout here if you don't understand something.
