Monsen
Monsen
- Monsen
- 661
- Administrator
- 8,864
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Community Atlas 1000th map Competition - with Prizes [August/September]
Campaign Cartographer 3 does not understand the command
Just for the sanity check, I assume you have tried restarting CC3+, as well as also trying with a new map.
There are situations where a command can "hang", but restarting CC3+ should take care of that. Do you experience similar issues with other toolbars, or just the Source Maps ones?
As for the buttons not having any tools, these tools are connected to the style of your current map. So if you start a new map in say Dungeons of Schley, it is quite natural that the park button doesn't have any tools, because there are no tool sin that style named "Park". These buttons are actually just filters, that show all the tools belonging to the current style that matches the filter set by the button. The Park button from CIT is unlikely to produce any results with most styles except the SM Cities style map itself since it is a specialized tool made for that style (which is also why the Park button doesn't normally show up, only when you switch to that add-on. It is possible to change your map to fetch tools from another style, but you're unlikely to actually want this as their visual style aren't designed to mesh well with your current map, whatever that might be.
WIP - Not In Time Atlas Contest - I have nowhere to put this anyway, Map
Links stopped working
I haven't noticed this before, but it does seem that something weird happens to the hyperlink if you change text properties on it using the change properties dialog. I've reported this to the developer.
For now, I recommend being careful with change properties and make sure only the text is selected and not the hyperlink (You can always make hyperlinks temporarily visible from the View Menu)
You should be able to make new ones though, at least I was able to after reproducing your issue. Just make sure to draw the hotspot properly around the entire text to link, the hotspot is a separate rectangle, not actually part of the text.
[WIP] 1000th Map Competition: Elkton, Alarius North Central
