Monsen
Monsen
- Monsen
- 661
- Administrator
- 8,864
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Distance Information
Which box is used depends on which menu set is in use. The newer version (2-lined one) is used in the menus for some newer add-ons like SS4, while you should see the old one in for example the standard overland menus.
Basically, these are two different commands, DISTANCE and DIST2. You can always ensure that you get the one you want by just typing the right command into the command line instead of using the menu.
As an alternative, you can edit the affected menu files in a text editor (the .mnu files in the CC3+ data directory) and just replace all instances of DIST2 with DISTANCE in there.
Community Atlas 1000th map Competition - with Prizes [August/September]
Thanks to all who participated. It is now well past the deadline, so I am closing this thread.
A new thread with an overview of the submissions and voting will appear in a few days.
If you were working on a map, but weren't able to finish it in time for the deadline, I would still be happy to have it for the atlas, just submit it when you are ready.
Menu_recovery.bat?
Koehaithian Realmdom (More Natural Edits)
I like the idea about making songs for your world. Pretty interesting what you can do with these new tools these days. It makes the world come alive in a way that was impossible before (unless you have a musician friend with ample spare time).
The link to the high-res version of your image doesn't seem to work. You may wish to post it in your gallery here on the forum instead.
