Monsen
Monsen
Monsen
660
Administrator
8,858
Birthday
May 14, 1976
Bergen, Norway
Website
https://atlas.monsen.cc
Real Name
Remy Monsen
27
  • Adding Symbols to Catalogs
    Just open the existing catalog files in CC3+ (open them in the main window, as a map, and not just in the symbol catalog window).
    Now you can use Import png's to import new images, or if these images are already defined as a symbol in another symbol catalog, open that symbol up in the symbol catalog window, and click once on each symbol you want to import. When done, just hit save and you're done.
    ScottA
  • Importing from a png
    Hi Vorapsak, and welcome to the forums.
    CC3+ isn't an image editor, and as such cannot work with your .png directly, but you can import it as a background image and then trace over it.
    To import it as an image, simply use Draw -> Insert file. Note that before you do this, I recommend you make a new sheet to hold the image, and make this sheet the active sheet before importing the image. Having it on it's own sheet means you can more easily move it up/down in the drawing order (Sheets in CC3+ are analogous to layers in gimp, while layers in CC3+ is just a grouping mechanism, which doesn't control drawing order of entities.
    Note that when inserting an image files, CC3+ only inserts a reference to the file, so once you have done this, you cannot move/delete the source file, otherwise it will just show up as a missing image (red X) in CC3+.
    Please don't hesitate to ask if you have any questions about this. You'll also find some basic information about this starting on page 94 of the user manual (ignore that it talks about hand-drawn maps, the only difference between a hand-drawn one and one from an image editor is that you need to scan the hand drawn first to get it as an image)
    AtomicTiki71ThomasHendrich
  • Community Atlas - Etrani Estate House, Calosirto Village, Ambraci
    Lorelei's Etrani Estate is now in the atlas. Thanks for yet another great set of maps.
    - 1st Floor
    - 2nd Floor
    - Cellar
  • Middle Earth map for children
    Posted By: JensenDoes anybody has a possibilty to upload the map that our US friends also may download it?
    I've put it on the atlas site. http://atlas.monsen.cc/atlas/middle%20earth%20for%20children.png
    Posted By: JensenI changed the map title to English and the scale to Miles
    You're walking down the dangerous paths of complication here :) Not everyone who uses English will prefer miles.
    arsenico13
  • Cartographer's Annuals and content
    All annuals have their own set of pages with description of each issue, including a image gallery. You can access these from the Products menu on the main profantasy website. Here is thew link to the 2007 annual, there are links tot he rest from that one.
    Kevin
