Monsen
Monsen
Monsen
661
Administrator
8,864
Birthday
May 14, 1976
Bergen, Norway
Website
https://atlas.monsen.cc
Real Name
Remy Monsen
27
  • Hi from Tony (aka. Tonnichiwa) {Now with actual pictures}
    @Tonnichiwa wrote:
    But I keep getting distracted because I am still trying to learn to code. I've got most of the HTML language down and the same with CSS (Cascading Style Sheets). Now I'm working on learning Javascript. Sometimes I wonder how all of you computer coders out there were ever able to learn all of this stuff!
    Ah. Coding is great fun. I remember I started back when I was about 8, had just gotten my first computer, a Commodore 64. Those were the days. Plugging away in BASIC.
    Once you've grown up from this web stuff, you should learn C++, then you can follow my XP tutorials and learn how to program addons for CC3+.
    MapjunkieJimP
  • Tilkar map
    Came out beautifully.
    Medio
  • How do I make overlaying grids?
    Use Draw -> Hex or Square Overlay
    Note that CC3+ doesn't allow automatic creation of grids with variable thickness. You could either make two grids, or, since it sounds like you won't have that many whole-inch squares, you could probably just change those lines manually. The grid is a grouped entity, but you can unlock groups by hitting the Locked button in the bottom right, and now you can just use :CC2MCHANGE: on the grid lines you need to make thicker.
    Note that you normally make maps in CC3+ in real-world scale, not paper scale, so grids aren't normally specified in inches, but since this is a rather abstract map, then perhaps you should just treat one map unit as one inch in this case.
    suncrushjmabbottJimPLoopysue
  • The Misgivings (Rise of the Runelords spoilers!)
    All images in posts are scaled to 1500px, regardless of the size limits. I thought I wrote that somewhere, but who knows where.
    Images in posts are generally intended to be viewed in the post so allowing images much larger than fits in a post is generally a waste of bandwidth, and slows down page loading.
    There's nothing wrong with putting WIP images in the gallery though. You may wish to have a separate album for them.
    Raiko
  • Grimdark Fantasy (renamed "Darklands") - development thread
    It's more about the tone of the settings than the colors of the map. Just think "the world is not a happy place" and adjust whatever you need to accomplish that. Ruins, war and conflict are all central elements.
    Loopysuejmabbottkristof65
