Monsen
Monsen
- Monsen
- 660
- Administrator
- 8,858
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Community Atlas - Fonlorn Archipelago - Bleakness - Death Forest.
Here's most of the maps from this set included in the atlas. Which means we have now surpassed 1100 maps.
@Ricko I couldn't process Hearthglen, you had uploaded the wrong fcw to the post.
Symbol Offset
This is a property of those symbols, standard behavior on the SS5 trees.
This setting is often configured for symbols that you may want to place along another entities, but should not go in the middle of the other entity, such as a alley of trees along a road (or in a dungeon, torches on a wall). It allows you to easily make sure all of the entities have the same distance from the centerline of the target entity.
The reason you don't see it every time you place a tree is that it is only triggered if you actually align the tree to something else. If it is placed in free empty space, there is nothing to align to, so this step will be skipped. To force this behaviour, when placing trees, move your cursor over a line/poly entity in your map, such as a road. You'll notice that once your cursor is over the center line of the road, the tree will rotate itself to align with the road ("aligning" for a tree may not be very obvious, but you'll see it rotate anyway), and if you click to place when it is in this state, you will get the Offset behavior.
If it just seems to happen out of the blue, for example in an empty area, there probably is a line or edge of a poly hidden on a sheet behind there somewhere. Even if you can't see it, CC3+ will detect it.
Drawing a perfect spiral?
Background Bitmap fills
You can change the scaling of the fill.
If you click the FS indicator on your status bar to get to the fill style dialog, go to the bitmap files tab, and pick the relevant fill in the dropdown, you can change the values under "scaled" to change the size. Larger size means less tiling, but remember that the resolution of these fills aren't infinite, so they will appear pixelated if you set this too large.
Importing the water tool from another map's style
You can just pick a different drawing styles from the :CC2DRAWTOOLS: window.
But you will need to import the fills first, have a look at this FAQ topic.
