Monsen
Monsen
- Monsen
- 660
- Administrator
- 8,858
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Setting all Symbol Catalogs to default
Note that if it is a single map, reinstalling will NOT help, as that won't change your map.
Just reinstalling the latest update won't help when restoring files to default, as that only replaces files contained in the update, i.e. things that have been updated since release, to restore original files you need to run the original installer (CC3+ base or add-on, depending on what you want to fix), and then re-run the latest update after doing that.
There isn't any restore to default feature except reinstalling. When you change the symbol catalogs, you do changes to the actual catalog and configuration files, and these are persistent. There are no "default settings" for most things in CC3+, other than to replace the various files with clean versions.
If it is just the map settings in a single map that is messed up, causing it to load wrong catalogs and tools, you need to hit :CC2PRESETS: and set the map style back to the correct style for that map type, and if you have changed the OnOpenMacro map note, revert it back to the original settings by just copying the macro commands from a fresh map in the same style.
Video tutorials for beginners
New Overland Map with Alyssa Faden & Friends
Community Atlas Project - Download information - Contributions Welcome
So, I put together a video showing how I prepare atlas maps and discuss some of my tools. It is a bit on the longish side, but I suppose it could be interesting for some.
The sound is not perfect unfortunately, something up with my mic config. I'll get that sorted for my next video, but it is still fully watchable.
Note that the reason Sue's map was wrongly scaled here was that she though the city was in metric scale, which is quite understandable because it is actually started on a metric template, but the sizes of all buildings and symbols used are in imperial, something I hadn't noticed before the contest.
