Monsen
Monsen
Monsen
660
Administrator
8,858
Birthday
May 14, 1976
Bergen, Norway
Website
https://atlas.monsen.cc
Real Name
Remy Monsen
27
  • Atlas Competition - The Divide
    Something like this?
    TheschabiDaltonSpenceLoopysue
  • Duplicating Effects Between Sheets.
    There is a copy button in the effects dialog. Just highlight the effects to copy and hit it.
    illuminatispy
    I think this is close to the final appearance for this map. Maybe some tweaks, but other than that, the map is done.
    Image below shows map with a grid.
    I am using a wall mask which is just the background multipolied with the floor to hide the grid and effects outside the walls. I am also using the color key effect both to break open the central room, as well as hiding the grid over the canyon.
    This is intentionally a small place, but for a bigger map, pretend those are 10 foot squares instead of 5.
    LoopysueBlackYetiAutumn GettyWeathermanSwedenDaltonSpenceOverCriticalHitWyvern
  • have you tried downloading and installing Vintyri 2.1 ? Don't ( Problem fixed.)
    Mark have fixed this issue now. It was caused by an issue with the old installer version. He's built a new version, 2.2, which is now available for download from the same location as the old one.
    There are no differences in the content between this new installer and the previous 2.1 from the site, so anyone running the current version don't need to go get the new one, the only difference is that the new version don't try to uninstall stuff if you upgrade from a previous version using it. If you have downloaded the 2.1 installer but haven't used it yet, then you should probably go get the new one instead, but again, this issue was only a problem if you already had an install of the CSUAC and tried to upgrade it, it was never an issue for new installs.
    LoopysueJimP
  • How to add large symbols to a city map
    Either set the line width before you draw, or use :CC2MCHANGE: on the paths in the drawing.
    Driechel
