Monsen
Monsen
Monsen
661
Administrator
8,858
Birthday
May 14, 1976
Bergen, Norway
Website
https://atlas.monsen.cc
Real Name
Remy Monsen
27
  • And another small map, this time in SS2 / CSUAC2
    Another great looking map. Well done.
    Daniel Pereda De PabloOctorilla
  • Full Reinstall - What Can I Skip?
    First the 2 BOH files , I think I do not need them as they are collections of stuff in the annuals, correct?
    Those are the floorplan and battlemap collections right? If so, yea, they are already included in various other products/annuals
    Then CD comes with "Random city" and "Celtic buildings" - are those not covered by other installs?
    And DD has "Shessar's fireplace symbols", again do I need to separate the separate install?
    These needs to be installed separately.
    Last the various dowonload options had in them various manuals, are those not the same PDFs we get when doing the install?
    Yes
    Last - Backup options. Is copying the full directories where all the Profantasy files live enough? Or do we need to register dlls and copy stuf from the Registry to get a full proof back up.
    For a full backup, you do need the data directory, install directory, and registry data. No dll's needs to be registered. But I'll normally recommend just backing up the data directory, and instead of backing up registry/install, do a new install and then copy over the data directory (avoid overwriting newer files).
    Traveller
  • Amonkhet maps
    How are the effects defined? If the effects are defined in percentage of view width instead of map units or percentage of map extents they tend to disappear when you export the whole map, because the actual "view" during a high-res export is pretty large.
    Dak
  • Map overlay?
    Draw menu -> Insert file. Create your temporary sheet and layer first, and make those active so the image goes straight to them.
    Umbratikus
  • Map overlay?
    Yes.
    Just put the image on it's own Sheet and Layer so you have easy control over the order and can change the order by moving the sheet.
    Umbratikus
