Monsen
Monsen
- Monsen
- 661
- Administrator
- 8,860
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Getting an Error
That message shows up because there aren't any wall tools in that style, nothing wrong with your installation.
The forlorn cottage style is a very limited style, and works best when used along with the Dungeons of Schley style, in which it is fully integrated.
If you click the :CC2DRAWTOOLS: button and select SS4 Dungeons of Schley as the style, you can access the full set of tools. The choice is remembered for the rest of the session, so you can use buttons like the wall button after doing that. (Note that this works between these two styles because they are integrated into each other, it won't work with other styles without also first importing the fills from the other style.)
And another small map, this time in SS2 / CSUAC2
Full Reinstall - What Can I Skip?
First the 2 BOH files , I think I do not need them as they are collections of stuff in the annuals, correct?
Those are the floorplan and battlemap collections right? If so, yea, they are already included in various other products/annuals
Then CD comes with "Random city" and "Celtic buildings" - are those not covered by other installs?
And DD has "Shessar's fireplace symbols", again do I need to separate the separate install?
These needs to be installed separately.
Last the various dowonload options had in them various manuals, are those not the same PDFs we get when doing the install?
Yes
Last - Backup options. Is copying the full directories where all the Profantasy files live enough? Or do we need to register dlls and copy stuf from the Registry to get a full proof back up.
For a full backup, you do need the data directory, install directory, and registry data. No dll's needs to be registered. But I'll normally recommend just backing up the data directory, and instead of backing up registry/install, do a new install and then copy over the data directory (avoid overwriting newer files).
Amonkhet maps
Map overlay?
