Monsen
Monsen
- Monsen
- 660
- Administrator
- 8,858
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Live Mapping - Village Battlemap
Here's the map, but you'll need Annuals 2021 and 2022 and Symbol Set 2 to use it.
We all know that villages only exists for the purpose of attracting monsters and other evil-doers that the heroes can fight, so we need battlemaps for them. Let's address that in the next live mapping session.
The time in your time zone can be found in the left sidebar, or you can click through the video to the youtube page where you can see both the time and have the opportunity to request a notification.
Galery of NPC
Yes. Just pick the CA Pro template instead of the CA3 template. Or for a full selection of the old templates, use the "Pick a pre-defined template" option in the first step of the new map wizard, then in the template select box, hit Select Path and navigate into the CAPro folder and into the desired subfolder, pick any of the templates and hit ok to preview them all in the template picker dialog.
New user here. Is it possible to make a multilevel dungeon with Perspectives 3?
My keep right here is essentially a multi-floor perspectives map (needs some zooming in):
Do note that it can be pretty confusing handling the floors. While it is perfectly doable, Perspectives itself doesn't really know what a floor even is, it just works with surfaces. It is up to you to position those floor surfaces to make the illusion of floors look right.
Drawing a perfect spiral?
