Monsen
Monsen
- Monsen
- 661
- Administrator
- 8,864
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Looking for a rising sea level map
Joint work with a colleague architect and the results are stunning!
The Sunken Temple
Community Atlas: Errynor - Aak and the Aak Hills
WIP: Fane of the Swamp People...
If you have the crop image to aspect ratio option on when exporting, you shouldn't get those white bars on the top/bottom.
The dungeon I started with is actually a below ground level, rather than an above ground but hey, what can you do?
It gets a bit more interesting when using the dungeon walls, since a regular floor mask would cover up all the unevenness of the stonework. But I am wondering if you could use TRACED to generate a polygon made up from the total area of both the floors and walls here, perhaps with a distance of -0.5 or something like that to make the mask "hole" for the dungeon to give that below ground feeling. Probably need to do something with the path to the entrance too though, to make it look like it is sloping downward towards the entrance.
