Monsen
Monsen
- Monsen
- 661
- Administrator
- 8,864
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
CA169, not all vari-color symbols have square upper right ?
CC3+ version 3.96 - Public Beta
Suggestions on making a good Symbol for Massive Tall Elven Trees
I have not figured out how to scale them to the same size as Mike Schley's trees, other than by holding Control and just resizing them
Bring up one of the Schely trees for editing from the Symbol Manager, and then use Tools -> Distance to measure the height of it.
Now, edit your own symbol, and just scale it up so the height matches.
Note that your symbols should be edited in the source symbol catalog where you have them, if you edit the symbol from within a map where you have used it, only the copy stored locally in the map will be changed. Also, when you change it in the actual symbol catalog, be aware that maps that already use the original smaller version will continue to use it (because symbol definitions are copied from the catalog into the map on first use) unless you first purge it from the map.
Mountain-side thing
Where can I find great resources for the creation of a subterranean world?
Maybe the Dungeon Worlds annual can be a good start?
Won't help you build crystal cities (not sure about resources for that), but it is a nice way of mapping an Underdark-like world.
