Monsen
Monsen
- Monsen
- 663
- Administrator
- 8,865
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Altering Color Palette on Annual Symbols (Spectrum)
After changing them (I recommend taking care not saving over the originals, and keep your own modified version in a separate folder with a slightly edited filename). You can then import the symbols into the map using Symbols -> Import PNGs.
After that, you can open the symbol manager, and find your imported symbols (they will be at the bottom). Select all the new symbols, and hit the save as catalog to save it as a new symbol catalog. Now, open the new symbol catalog as if it was a map (instead of into the symbol catalog window), go to the symbol manager again, but this time, select the symbols and hit properties. From here you can set up options like symbol groups and random selection from groups. Just save the file normally when done.
From now on, you can load this new symbol catalog into the symbol catalog window when working with a map and use it like any other catalog.
Community Atlas: Embra - Travelling Places
Community Atlas: Embra - Hilly Places
Forgotten Realms Interactive Atlas repairs.
@thehawk wrote:
Is there a way to harvest links out of the map files without having to visually scan each one?
You can just list out all the hotspots
LIST -> hit T (for entity type) -> check the Action: 2D Hotspot option -> Hit OK -> hit D (for do it)
The great thing here is that CC3+ remember the checked option in the entity type list between maps (in the same CC3+ instance) so the next time you hit T to go into that list, the 2D hotspot option will already be checked so you don't have to scroll through looking for it every time. (You still have to open that dialog every time though to add entity type as a criteria)
It shouldn't be hard to write an XP module that lists all the links in a map either, and combined with the MULTIFILESCRIPT command should allow all links in all maps to be listed.
In the Shadow of the Dragon
