Monsen
Monsen
Monsen
663
Administrator
8,865
Birthday
May 14, 1976
Bergen, Norway
Website
https://atlas.monsen.cc
Real Name
Remy Monsen
27
  • August Mapping Competition - Vote for the Winners - Vote closes Sept. 8th.
    So, with august firmly in the rear view mirror, the competition is over and it is time to vote for the winners.
    As stated in the rules, there will be two categories to vote on. Think these through when voting, best map and most visually stunning map isn't the same thing, mapping is more than making things beautiful.
    • Best Building: Who made the best building overall. This includes all the floors.
    • Most interesting floorplan: Which floorplan is the most interesting one? A floorplan can be interesting because it has a special twist, because it is very highly detailed, because it has an interesting story, or whatever you think makes it interesting. Note that this is judged on the basis for each floor, not the building as a whole. For this category, visual looks is low priority, unless the visuals is what makes it interesting.
    I am giving everyone two votes here, which means there are 4 poll questions below to answer, 2 for each category. Please vote even if you didn't take part in the competition.
    I am going to keep the poll open for a week. I am also drawing the two random prizes at the end of the vote.
    And as usual, don't despair if you end up with 0 votes. The number of people voting in these contests aren't large enough to give a proper distribution, so the votes tends to clump along the handful of maps that people like the very most, with the maps receiving few or no votes, even if they're not that far behind. That's what happens when you convert quality to numbers through voting.
    All submitted entries are included in the vote, but certain people, like ProFantasy employees and contest managers are not eligible for a prize, so if they get into the top, prizes will just move down to the next one in the list. Same if someone don't want their prize, or one person wins multiple (Each entry is only eligible for one prize)
    The entries are presented below
    Daniel Pereda De PabloLoopysueAleD
  • Cats & Maps
    So, why draw maps yourself when you can just have the cat do it for you?
    JimPLoopysueMapjunkie[Deleted User]ScottADaltonSpenceMaidhc O CasainWyvernJulianDracosWazzebuand 6 others.
  • August Mapping Competition - Building Floorplans - Win Prizes
    Guess I'll make sure to actually submit my own entry as well. Here's the final version of the little smithy.
    WeathermanSwedenLoopysueWyvernDaniel Pereda De PabloShessarroflo1DaltonSpenceMaidhc O CasainAleDarsenico13
  • City of Torlok
    The reason for the bad resizing behavior is that you have lots of things on your MAP BORDER layer that doesn't belong there. There's a lot of buildings there, and most of the city wall is there too. This confuses CC3+.
    To fix it, show just the BUILDINGS sheet, then use the command Change House Layer on all the buildings, and change it to BLDNG (HOUSE 1). Then make a new layer, call it WALLS. Now show only the SYMBOLS 2 Sheet, use change properties on everything and set it to the WALLS layer. Do the same thing for SYMBOLS 3 sheet.
    Now, the resize command should work normally.
  • Green lines in roof of city buildings
    Turn off the demographics coloring: City -> Layers -> All BLDNGs with shading
    If that doesn't work, try hiding all the layers that start with BLDNG
    Jeff B[Deleted User]
