Monsen
Monsen
Monsen
661
Administrator
8,864
Birthday
May 14, 1976
Bergen, Norway
Website
https://atlas.monsen.cc
Real Name
Remy Monsen
27
  • Cc3+ text on non cc3+ map versus photoshop?
    You ask about text, but you also talk about things like political borders and stuff, so it seems like that should be taken into consideration.
    Now, to start, I personally hate PhotoShop, I find it cumbersome, difficult and intuitive to use, and on top of that, expensive. But, there are other image editors out there so I'll not jump to the conclusion of using CC3+ just because I don't like the other option.
    But, you obviously isn't skilled in PS yourself, given that you don't know the difficulty of working with text, which more or less brings me to a conclusion right away, use what you know. If you know how to do things in CC3+ there isn't really a good reason to use an image editor, unless you want to use it more as a training exercise to learn that software rather than use what would be most appropriate for you.
    Considering that both options do allow a layered approach, both can be used for the task, but if you import the map to scale in CC3+ before drawing on top of it, you can also use various tools to do things like measuring length and area, including measuring length along a curved line, which I personally find extremely nice when working with maps, so I would probably pick CC3+ for that option alone.
    The only reason where I feel the image editor may be a bit stronger is making the things you draw on top of the scanned image appear better "integrated" into the image. But this is something that takes skill with the image editor, it doesn't come for free, and you can get a long way in the same direction by using sheet effects.
    JimPOctorillaLoopysue
  • August Mapping Competition - The Results
  • Importing landmasses from images
    I would love to know if I can import my old maps as an overlay or better yet, for CC3+ to generate landmasses from my images.
    You can insert an image into your map using Draw -> Insert file. You can then either place this on a sheet below the one you draw on, or add a transparency effect to the sheet holding the image if you wish to have it as an overlay.
    CC3+ has a command called TRACED than can construct an entity from an image automatically, but this works best if the image is black landmasses/transparent seas, and it will only be able to handle the outline, it can't really do inland contours and things like that (unless you are able to extract those manually as a separate image to be processed.)
    can I make detailed regional maps from a bigger one in CC3+ without having to make a new project and trying to get the coastlines match? Meaning, is there a way to select a zone of the map and tell CC3+ to make a new project based on that?
    Yes. There are a couple of ways to go about that. All the options do require some manual work to get a good end result, but getting the coastlines is quite simple (Although you do probably want to add additional detail to a zoomed in part of the world). See here for one way to do it
    JulianDracosStoltverdLoopysueScottA
  • Cartographer's Annual - all the issues linked in one place
    I can't make all potential useful topics sticky, the front page would just be a long list of stickies, which is not very user-friendly. Instead, it is listed in the resources category, which you can find directly from the left-hand navigation menu (Helpful resources and FAQ link)
    EukalyptusNowroflo1arsenico13JimP
