Monsen
Monsen
- Monsen
- 661
- Administrator
- 8,864
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Community Atlas Project - Download information - Contributions Welcome
Community Atlas - Forlorn Archipelago - Fisher Isle, several villages and surrounding areas
August Mapping Competition - The Results
And here's @Maidhc O Casain's entry added to the atlas:
How do you attach a master symbol filter file to a map
Great. Means your issue is caused by the bug I stumbled over. Turns out notes also live on a sheet, so if you accidentally delete the one they're on (which there is no way to tell) you also delete the notes. Seems like they're on the LAND sheet for lot of the official templates (by pure coincidence), but no guarantee all templates are like that (probably not, since city and dungeon styles don't have a LAND sheet at all).
I've reported this to the appropriate authorities.
Deleting / Erasing along a line?
No, not that easily. If you are willing to do it with an effect, you can very easily draw a polygon along the road and use the color key effect to knock out those parts, otherwise you'll need to either redraw or modify the polygons.
Keep in mind that the drawing tools have a trace feature, so it is quite easy to draw a new poly that follows along part of the old one, and then draw the part along the road manually.
