Monsen
Monsen
- Monsen
- 661
- Administrator
- 8,864
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Little Bighorn Battlefield Map
Community Atlas - Arthenn / Berenur
@Ricko Hasche I wasn't able to include the dragon map, as it contains unknown symbols. You'll need to edit it and replace these before I can use it in the atlas.
$____recursos mapas\MIKE SCHLEY PRESETS\arvore fogueira buraco\SS_TS005_006_Ground_Burned_Small_02_LG.png
$____recursos mapas\MIKE SCHLEY PRESETS\arvore fogueira buraco\SS_TS005_037_Smoke_Small_02_LG.png
Also, please make sure to check the scaling on your maps. A couple of them was badly scaled. For example, the scale bar in the Burned Emptiness was off, showing 200 while it should have been 100, while the actual map was correctly scaled (determined by looking at how it fit in on the overview map of the region). Some other maps had the opposite, where the scale bar values was logical, but the map itself was wrongly scaled.
You can easily check that the map and the scale bar matches up by using Info ->Distance and just measuring along the length of the scale bar. CC3+ should return a value equal to the length of your scalebar, if not, one of them is scaled wrong. You then need to determine if it is the scale bar (if so, you can just relabel the length on it) or the map itself, in which case you need to re-scale it.
I also believe that some of the maps have both a wrong scale bar and incorrectly scaled, as the length of the scale bar is correct when measured, but they don't seem to fit correctly in on the main regional map when plotted in at the correct size. This applies to the Hafr and Laugar maps.
Note that if you need to make changes to the maps I have already included in the atlas, it is important that you edit the files from the atlas, and not your own originals as that would delete the work I have already done in integrating them.
Live Mapping - Cemetery
I am going to need a cemetery battle map soon, so why not dive into it in a live stream. Nothing like working on a map for actual use.
Stream will go live on Thursday at 18:00 CET as usual. Check the upcoming section in the left forum toolbar for the time in your timezone, or click the video below to have YouTube tell you.
Community Atlas - Berenur - Urtrah Desert
This batch of maps have now been added to the atlas. Thanks for a great contribution @Ricko Hasche
This set also put us above the 900 map threshold. This means we are now clearly larger than the old FR Atlas.
