Monsen
Monsen
- Monsen
- 660
- Administrator
- 8,858
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Community Atlas - Irisian City States - Dimitrios island
@Ricko Hasche wrote:
how i can do this master @Monsen ?
Reducing the scale of a single fill is just a matter of opening up the fill style dialog, selecting the appropriate fill, and reduce the width/height values.
Symbol Scaling & Position
This is due to the setup in that traveller catalog you are using. For the standard traveller map, a gas giant is treated as a modifier to an existing symbol, to be displayed in the corner of a hex, not in the center where a regular planet goes.
This means that the symbol is quite offset from it's origin, which should be noticeable already at 1x scale, but as you scale up, distances are also scaled obviously, meaning that distance is now 16x larger. (This special placement for traveler is also why it is so small)
The gas giant in the regular planets catalog is more normal, but that is a height symbol, which isn't what you want here.
My recommendation is to create your own symbol catalog. Just make a copy of the traveller one, and then go in and scale all the symbols so they are properly scaled related to each other, and not for the abstract traveller use, and change the origin of the gas giants to be in the middle of the planet.
How long have you been using Campaign Cartographer?
That's a pretty good question. The earliest map I could find in my collection that I actually made and used for a game is dated 2005, but that was not the first time I used CC.
I think my first encounters was with the cut back version - Campaign Mapper - which shipped with the Core Rules 2.0 product back in 1999. I remember picking this up pretty early after it's release. I think I also got the FR Atlas around that time, probably around 2000.
Most of my early maps were simple modifications of the FR Atlas maps.
Problem with red marks appearing on maps
