Monsen
Monsen
- Monsen
- 660
- Administrator
- 8,858
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Community Atlas - Drachen Temple Battlemap
This batch of maps now processed. Thanks for the contribution @Ricko
We're now up to 1038 maps in the atlas, but I still have quite a few in my processing queue.
Just a thought Remy, but if there are still area maps needed for this, maybe you could list them on the Forum, and have folks here volunteer to do one or two each?
It's not more maps that is is needed, but the fact that many competition maps were set on overland maps that were developed at the same time, meaning I had to also process those overland maps before I could process the competition maps, leading to a delay in processing competition maps due to extra work needed up front.
unsure what I've done to the border
Whenever you have issues like this, it is almost always something on the wrong sheet.
Sometimes the easiest way is to go through the sheets one by one.
If you issue the command
SAUTOHIDEON
you put CC3+ into only displaying one sheet at a time mode. You can then go to the next sheet with theSNEXT
command or previous one usingSPREV
command, or to a specified sheet by using theSSET SheetName
command.There is a small bug where the sheet indicator in the status bar says Common Sheet even if that is not the active sheet. Issuing a REDRAW command (or Ctrl +R) updates this to show the proper sheet.
Once you have identified what is wrong, which should be obvious when you work through the sheets like that, you can turn normal sheet display back on and show all sheets with
SHOWSHTF *
Community Atlas 1000th Map Competition - The Winners
Here's the next maps from the competition integrated:
This concludes the maps from the contest (I hope. Let me know if I forgot anything), with the exception of @Lorelei's entry. I'll process that whenever she has the parent map ready.
Thanks to everyone who participated. This put us solidly past the 1000 map milestone. Currently, there are 1033 maps in the atlas, and with all the maps that has piled up on the forum awaiting my processing, we are closing in on the 1100 mark.
missing Vintyri / Dundjinni symbols
