Monsen
Monsen
- Monsen
- 661
- Administrator
- 8,864
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Transparency Acne - Lesson Learned
This happens because the RGB Matrix effects is vulnerable to TA as well. It won't make gigantic holes, since it doesn't do any edge effects, but it still need to figure out what parts to color, so the same pixels that make giant holes with edge fade are left out by RGB Matrix, leaving the edge fade to produce the known and loved TA holes.
Community Atlas City of Tartateos - Shipyards District
Personally, I feel it needs more clearly defined streets. The continuous cobblestone fill looks a bit weird and unnatural to me. Even if a city did use cobbles for all it's streets (which is uncommon in itself), having it wall-to wall everywhere looks out of place, especially in places outside the main thoroughfares, like back alleys and backyards.
The Plague of Red X Symbols and Symbol Catalogs Not Importing
As Joe also said, don't rename your user profile. Windows will not like that at all. Instead, it is better to make a new profile using that name and just switch to that. But the desktop is really no good place keeping these files, so doing that is more a band-aid than anything really. As Joe suggested, it is better to fix the problem.
The command Joe mentions is documented in the Blog article, under the heading "Four B – Fixing the Map", under the subheading "Everything at Once" (But I recommend reading the whole thing, don't just that section)
As for symbol catalogs, you don't normally import those into your drawing. You open the symbol catalog in the symbol catalog window using the :ICON_CATALOG: button, and simply use the symbols from there. Symbols will then be imported into the map one by one as you use them from the symbol catalog (But do note that symbols are indexed by their name, so if you have a symbol with a certain name already in your map, it will use that, even if the one in the catalog is different but with the same name)
I made sure to keep those symbols and symbol catalogs I made to live in the same location in my new computer.
Are you 100% sure of that? I grabbed a random symbol that gave me a red X and the path of it was C:\Users\Jer\Desktop\Mirage\The World of Mahdran\Massive World of Mahdran\4x4 Massive World\Grey Spectrum Mountains\Stones\Lavastone.png
Now, this immediately rises some red flags, because even if you did put the symbols on the desktop of the new computer, the path would only be the same if your username ("Jer" in this case), is the same on your new computer. If it isn't, then putting them on the desktop on the new computer will not result in the same path, the only thing you can do in that case is to manually recreate that exact path (Windows doesn't mind you creating additional folders under "Users" even if it isn't a user, but you need admin privs to do so.)
(You can check the actual path by right clicking on any of your images and select properties, the properties dialog will contain the full path of the current location)
Generally, keeping files on your desktop is NOT a good idea, precisely because of issues like this. I always recommend keeping all resource files inside the CC3+ data directroy, because that way, you can use relative references in your paths, meaning it will work even if the data directory isn't in the same location on the new computer.
There's a lot of information in this blog entry about dealing with this:
Problem with red marks appearing on maps
The first one seems to have red areas that look like terrain and not Xs.
It's just an illusion caused by the shape of the poly, the size of the red X, and the fact that it is in the background partially covered by other fills. Look closer at it, and you'll see the sharp straight edges between the red X and the white background.
