Monsen
Monsen
- Monsen
- 660
- Administrator
- 8,858
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
a prototype under ground home for a dragon and some questions
Did you also apply the color key effect to that sheet?
You can create cut-outs on as many sheets as you want, but there are a couple of things to check
For each sheet with a cut-out:
- There must be the color key effect on that sheet, and the color key effect must be the top effect in the list of effects for that sheet
- There must be a polygon in the cut-out color on that sheet, and that polygon must appear on top of the things you wish to cut
- And of course, the things to cut must also be on that sheet. Even if you set up the effect and poly correctly, it won't do any good if the entities to cut is on the wrong sheet. It only cuts things on the same sheet.
Editing continuous wall symbols.
Campaign Cartographer 3 does not understand the command
Just for the sanity check, I assume you have tried restarting CC3+, as well as also trying with a new map.
There are situations where a command can "hang", but restarting CC3+ should take care of that. Do you experience similar issues with other toolbars, or just the Source Maps ones?
As for the buttons not having any tools, these tools are connected to the style of your current map. So if you start a new map in say Dungeons of Schley, it is quite natural that the park button doesn't have any tools, because there are no tool sin that style named "Park". These buttons are actually just filters, that show all the tools belonging to the current style that matches the filter set by the button. The Park button from CIT is unlikely to produce any results with most styles except the SM Cities style map itself since it is a specialized tool made for that style (which is also why the Park button doesn't normally show up, only when you switch to that add-on. It is possible to change your map to fetch tools from another style, but you're unlikely to actually want this as their visual style aren't designed to mesh well with your current map, whatever that might be.
WIP - Not In Time Atlas Contest - I have nowhere to put this anyway, Map
[WIP] Order of the Fist Monastery
