Monsen
Monsen
- Monsen
- 660
- Administrator
- 8,858
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Installed Add-Ons List
Humble Bundle
Pseudo-Architectural Shenaningans (WIP)
@DaltonSpence wrote:
could you explain in more detail how to load the CAD blocks as symbol catalogs? I haven't downloaded one yet but I'd like to be prepared. I'll probably do some editing since I like to simplify things anyway.
Just hit the :ICON_CATALOG: button and load the file. Note that it doesn't have a filter by default for .dwg files, but all you have to do is to enter *.dwg in the file name field and hit enter in the browse dialog, and then browse to the appropriate directory and pick the file, just as with a standard symbol catalog.
Note that some of these symbols are made with white lines only, which can make them rather invisible in the symbol catalog window, but you can change the default background color by going to View -> View-Window Color and setting another color. This will impact the mapping window too, but it won't affect prints or exports.
Bulkhead and door question - Cosmographer
Seems to work fine for me in your drawing, but notice this:
- Turn of snap when placing cutting symbols. Snaps modifies placement, which often lead to the symbol not aligning/cutting correctly
- I found at least one bulkhead in your drawing that were doubled up with two bulkheads on top of each other. The cutting symbol will only cut one, leaving the other, making it appear as if nothing were cut.
- Some of the symbols only cut the size of the actual door portion of the symbol, and not the doorframe, this can also lead to an initial appearance of not being cut until you look closer.
Setting all Symbol Catalogs to default
Note that if it is a single map, reinstalling will NOT help, as that won't change your map.
Just reinstalling the latest update won't help when restoring files to default, as that only replaces files contained in the update, i.e. things that have been updated since release, to restore original files you need to run the original installer (CC3+ base or add-on, depending on what you want to fix), and then re-run the latest update after doing that.
