Monsen
Monsen
- Monsen
- 661
- Administrator
- 8,864
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Question re scale.
Pixelated Drawing Tools in DD3
Change the display quality using :CC2RESMODE:. Set it to Fixed - High or very high. After doing that, you can try setting it back to automatic and clearing the bitmap cache, but if the issue remains, just leave it at fixed.
CC3+ uses 4 different resolutions for performance reasons, and what you see here is one of the lower texture resolutions being displayed instead of the higher one that probably should have been displayed in that situation.
Note that "Sample size" is just the size of the sample window, it doesn't affect the drawing.
How do I get my new maps onto Roll 20?
2 questions: "broken" sheet and effects on load
This is a lesser-seen case of the 'Transparency Acne' effect. CC3+ calculates edges by looking for differences in colors.
What happens here is that the lines doesn't go on top of the text, but because the text appears on top of the halftone lines, CC3+ sees differences where the fill has white pixels, and unchanges where they are black. This causes the glow on the text to behave as if the text was full of little holes, and fills those holes with the white glow.
The best way of handling that is to change the colors on your underground railroads from black to a dark grey, just pick the darkest one. Since it isn't black, CC3+ will see that as a difference, and you are fine.
Crash with "Cosmographer Deckplan Bitmap"
