Monsen
Monsen
- Monsen
- 661
- Administrator
- 8,864
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Problem with layers
connecting passageways for Cosmo star ships ?
Changing Fill Color
The wave fill is defined in each template, so you'll need to edit it for every map you want it changed in, but what you can do is to go to Symbols menu -> Symbol Manager, then check the box that says display fill style symbols. You should now find the Wave fill symbol in the list. Select it, and hit edit. Define the two corners of the editing window as CC3+ asks you to do, and then simply use :CC2MCHANGE: on the waves and make them black. Close the editing Window, and say yes to keep the changes.
Is there a way to divide a City Map into smaller Battle Maps?
Well, if you just want to use that zoomed-in portion as it is, then all you have to do is to use pick Rectangular section JPG when you save the map, this causes CC3+ to prompt you for two opposite corners that define your export area instead of exporting the entire map, this allows you to export arbitrary (rectangular) portions of it.
CC3 Spectrum Overland "Symbols in area" function
