Monsen
Monsen
- Monsen
- 661
- Administrator
- 8,864
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
CD3 House Settings - Not showing CA63 fills
Province borders on Overland Hex map
Editing terrain symbols
This isn't a symbol, it is a drawing tool. The "thing" in the symbol catalog is a fake symbol to allow drawing tools to be show in the symbol catalog.
You'll need to edit the drawing tool itself, but note that the fill used by this tool is a hatch style, which is a fill defined in a separate drawing found in @Hatch Styles
Is there a way to divide a City Map into smaller Battle Maps?
The PPI setting is a meaningless value outside of print calculation. Just completely ignore it and always just concentrate on the width/height in pixels.
The important thing to check is that both height and width is set correctly, since CC3+ will crop the value if necessary to retain the ratio. (Well, technically, all you have to do is to get one correct, and just set the other one to a really high value, since it will be capped at the max allowed by the aspect as long as the rectangular section is specified correctly.)
When doing the rectangular export, for perfect precision, I recommend turning on cursor snap so you don't have to align them perfectly manually.
To make sure the export is done correctly from CC3+, you should be able to check that the pixel dimensions are correct from the file properties in Windows (or by opening it in an image editor)
