Monsen
Monsen
Monsen
660
Administrator
8,858
Birthday
May 14, 1976
Bergen, Norway
Website
https://atlas.monsen.cc
Real Name
Remy Monsen
27
  • [WIP] Wizard's Tower - Interior
    If you need to know exactly what is from which add-on, you can use the IRD command (D stands for Detail).
    And that cobble fill is some weird reference that turns up in some templates.
    LoopysueRoyal Scribe
    Ah, yea, you need a newer build of the dll file too.
    I've uploaded an updated zip with a new dll file too. Remember to close all instances of CC3+ before replacing it.
  • WIP Community Atlas - Mortyn-Goya Confluence
    Yea, that's DELAYDRAWSYM.
    That setting is system-specific and not map-specific, so it won't be automatically turned on when people load the map unless is it is added to the map loading macro.
    KertDawg
  • Why do sheet effects turn off?
    I can't provide a full explanation here, especially since this isn't really something I have really noticed myself.
    But let me address one thing at least:
    It also happens a lot on loading a map, even when it's a CC3 window that's already open with the box checked.
    All CC3+ maps have a setting that determine if effects are on or off on load, you'll find this in the :CC2RESMODE: dialog. This is a per map setting. If this is off, the map is loaded with effects off, even if it was turned on inside CC3+ previously. You can override this behavior from Tools -> Options
    Now, while you experience that effects randomly turns off, I don't know, but i suspect it could be due to loading a file that sets this value. There are lots of cases where CC3+ loads map files, for example, symbol catalogs are actually just map files with a different extension, and drawing tool previews in the symbol catalog window can also be map files. I am suspecting that maybe the value is incorrectly set when something like this is loaded.
    Royal ScribeCalibre
