Monsen
Monsen
- Monsen
- 660
- Administrator
- 8,858
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
[WIP] Wizard's Tower - Interior
I wrote a tool for that: http://cc.monsen.cc/tools/cc3monsentools.html
WIP Community Atlas - Mortyn-Goya Confluence
Why do sheet effects turn off?
I can't provide a full explanation here, especially since this isn't really something I have really noticed myself.
But let me address one thing at least:
It also happens a lot on loading a map, even when it's a CC3 window that's already open with the box checked.
All CC3+ maps have a setting that determine if effects are on or off on load, you'll find this in the :CC2RESMODE: dialog. This is a per map setting. If this is off, the map is loaded with effects off, even if it was turned on inside CC3+ previously. You can override this behavior from Tools -> Options
Now, while you experience that effects randomly turns off, I don't know, but i suspect it could be due to loading a file that sets this value. There are lots of cases where CC3+ loads map files, for example, symbol catalogs are actually just map files with a different extension, and drawing tool previews in the symbol catalog window can also be map files. I am suspecting that maybe the value is incorrectly set when something like this is loaded.
