Ricko Hasche
Ricko Hasche
Ricko Hasche
4,070
Member
8,029
Birthday
February 7, 1977
merlo san luis argentina
Mapmaker
20
  • Looking for Symbols
    CA80 Hy Space Systems have those i use sometimes.
    Royal Scribe
  • Hex map
    "something" like that.
    the idea of ​​using the icons of the intersections between the "kingdoms" as if it depended on a passage from one to the other.
    Or... yet another possibility would be to use different races/cultures/construction colors in each sector.
    LoopysueMapjunkie
  • Hex map
    Making Hex maps with "separate" themes: deserts, forests, mountains, etc. I got the idea of ​​using these small maps to produce a whole map, divided into "zones", and making them one by one. I asked my brother to make shapes where the large Hexes connect to each other.
    I dont know if make 19 Hexes like in the drawings above (example pattern below), or make them in packs of 7 Hexes for reasons of better fit.
    What do you think about which image/pattern to work with? I still have no idea whether to use the white space in the center as an ocean and islands, or some kind of limbo and clouds.
    Thank you very much.
    Royal ScribeLoopysueMapjunkie
  • Hex map
  • Hex map
