Ricko Hasche
Ricko Hasche
Ricko Hasche
4,077
Member
8,039
Birthday
February 7, 1977
merlo san luis argentina
Mapmaker
20
  • Fast Marshes Tutorial
    this one is about marshes and wet areas mr quenten, how to give them a honest visual without using marsh fill style at begining or use marsh/swamp default terrain during the draw
    This is same effect/technique ive used in elven Comune to make the rice fields on comunity atlas
    [Deleted User]
    13 - Add the interesting points (ruins, cave, village etc) and in 5 minutes your map is ready to game 🌹
    [Deleted User]LoopysueMapjunkieLautipablo gonzalezarsenico13Daniel Pereda De Pablo
    11 - Refresh
    Note: Ocean usually comes with the Edge fade inner effect, if you have to create your Sea LAKE sheet, don't let the Edge fade inner effect be included in this new sheet. It gives it a much more realistic look.
    LoopysueLautiJuanpi
    9-now the little secret.
    as the fill style of this drawing is not ocean, I can move Sheet Ocean below sheet Land (easier). In case you have Ocean as the base of your initial Fill Style, no problem, Create a SHEET SEA LAKE/MARSH/POOL etc and move that sheet below Sea (original) and LAND, and work on it.
    Sometimes the same thing happens when CC3 switches to SEA normal instead of SEA LAKE, as in the previous example of SYMBOLS TREES.
    LoopysueLauti
    6 - Create SYMBOLS TREES GRASS sheet, and place it above SYMBOLS BACK sheet. Select this sheet to work with and choose Scrub icon (grass).
    VERIFY if CC3 keeps the SYMBOLS TREES GRASS sheet or if it simply switches - it happens a lot to me - to the SYMBOLS TREES Sheet. In case of change, Select SYMBOLS TREES GRASS again
    LoopysueLautiJuanpi
