Ricko
Ricko
Ricko
6,056
Member
9,959
Birthday
February 7, 1977
merlo san luis argentina
Mapmaker
  • Map using Sarah Wroot Style
    very beautiful
    JimPC.C. Charron
  • On leprechauns and rainbows and pots of gold
    Note the tree in the highest part of the tower. This one is overcoming the tower. because the tree is in the sheet symbols trees and the tower in the sheet symbols, or both are in the same sheet symbols trees and the tree "was in front". The simplest solution is to delete this tree. Cheers
    Royal Scribe
    Hey @Royal Scribe Beautiful work! Note that in the first image, the waterfall is not in the foreground.
    In the second drawing, very beautiful by the way, you can improve it even further by using the trees or other symbols to "hide" the junctions of image with screen, or image with image. Note the points below.
    Also, if you want to show an apparent "use" of the magic circle of stones, you can leave it without grass and create a special sheet, above all, to use a hill background or mountain background and give the appearance of a ground "trampled".
    Congratulations!
    RalfRoyal ScribeJimPMapjunkieLoopysueCalibreGeorge
  • MY MUNDI IS READY!
    Saravagard - Land ruled by the Mighty Timelison Rego IV
    Cheers
    QuentenRoyal ScribeMapjunkieRalfMonsenLoopysueroflo1CalibreRaiko
    Bagoard, small bucolic feud from family Escrotar and Tyson.
    JimPRoyal Scriberoflo1QuentenMapjunkieMonsenGlitchRalfCalibreRaiko
