Ricko
Ricko
Ricko
6,755
Member
10,565
Birthday
February 7, 1977
merlo san luis argentina
Mapmaker
22
  • [WIP] Spectrum Overland Waterfalls x 2
    Hy Royal! Achieving depth of field with assets designed for a longer view can be tricky. One of the techniques I usually use to try to achieve this effect is to "strip by strip" progressively increase the size of some - but not all - icons.
    In this example, while I use smaller and smaller hills as they get closer to the observer, the trees instead gradually grow larger to create a greater sense of proximity and distance. In the case of this style, all the images go to the default Symbols, since there is no specific sheet for trees, like Mike Schley for example.
    In this case, as sometimes with Mike Schley, I have to put "everything on the same sheet" (in the case of Mike Schley I use all or most of the drawing on the TREES sheet) and go drawing layer by layer. It is always advisable to have a draft or sheet trace image with a very clear base transparency before starting, so as not to waste time and to make the task easier.
    If you want to add even more realism to these scenes, gently vary the size and types between trees "in the same tree range". I usually do this visually with the controller, checking every so often to see if it is within the acceptable size range for that location.
    Royal ScribeMapjunkieGlitchJuanpi
  • The Lands of Strauvuvrorr
    a large pack of structures expansion for Spectrum overland would be amazing
    Royal ScribeMapjunkieMonsen
    City of Ovuzz on winter.
    LoopysueMonsenRoyal ScribeQuentenMapjunkieRalfJuanpiCalibre
    Less Lines on Edge Stripe @Monsen
