Ricko
Ricko
- Ricko
- 6,718
- Member
- 10,550
- February 7, 1977
- merlo san luis argentina
- Mapmaker
- 22
Reactions
Western Baja California
i have it.
i follow C:\ProgramData\Profantasy\CC3Plus\Annual\Issue 132A - Sue's Parchments
select Scroll Sheet
went to Fs section you show me. select bitmap there (proved with many of your scrolls)
Then use Box draw tool on the right side and make a retangle to cover map area. then i sucesifully cover with new parchment selected.
i just cant get (tryed with many parchments) the "roll" effect on photo. i only can reach the "Flat Parchment".
this i make the question on last post, if need some tool or another file to get it?
Use Pär Lindström annual 2017 style and google maps to trace to fit a map to a friend history, on his own town La Paz.
Cheers
P.s.: @Loopysue im experiecing some problems to import the parchements.
i go tools> Import bit map fill stile> bitmap> tiles> parchments>132A> select my parchment> (turn on and scale Width and Height with my map size) OK
then appear me "6 fills imported into the current drawing". Visually nothing changes and i cant find it on layers.
thanks for Help
Ravenloft subcontinent/islands
Trim problems in navigation lines
