Ricko
Ricko
Ricko
6,722
Member
10,551
Birthday
February 7, 1977
merlo san luis argentina
Mapmaker
22
  • night landscape
    6 - Start now the settlement , sometimes if you want to hide some houses behind a hill or mountain to have more depth of view... i work puting some houses, go to hill, maybe a mountain, come back and place more houses... alternate this process until i like the results.
    7 - Note some possible tips on next figure: 1/ i use as i told place the houses (in a size that "my eyes liked"), after i place the mountain upon half of houses image to try get more depth. 2/ i normaly mirror all houses same direction cause the smoke in this case, give more reality as is same wind to all. 3/ jon roberts style all images have a kind of big aquarel shadow/mist in the end of the image, if you dont respect the correct distance, the effect from new one, over the last image.
    GlitchLoopysueLautipablo gonzalez
  • night landscape
  • night landscape
    Hy Rofl1,
    sorry my bad english but i will try to show my step by step.
    First i must say this is all Mr. @Quenten fault. When i reinstall cc3 and return to the forum after almost 10 years away, i saw on his posts some creation of "landscape" view - using cc3 overland - and that inspires me a lot. Then i started to pratice.
    Normally i project the map (overland, dungeons or city) before start to work on cc3, this method is more usefull to me. But this time i just want a castle-town between 2 cracks. so im not much shure about where to go.
    so the sequence was like:
    1. select jon roberts style and set 70 x 49 metrics do adjust to A paper family.
    2. select grey 20 on background
    3. place the 2 cracks not respcting the image scale x map size - normally when i make this kind of map, my guide is "the eye". And the cracks give me 3 spaces to work with perspective
    Loopysueroflo1JimPmlore95Lautipablo gonzalez
  • night landscape
    Used Jon Roberts Overland Style
    Shadows and moon was made in lightroom.
    Cheers
    roflo1MonsenTheschabiLoopysueseycyrusWeathermanSwedenScottARaikoDaltonSpence[Deleted User]and 17 others.
  • Ushuaia - End od the World - Land of Fire
    Initially Ithought in make solid road on map...
    but after i realize that Ushuaia was almost impossible to reach by land until around 1950... so was a perfect place for Argentina make a big prision there, cause escape was almost imposible. They have some historys from people who jailbreak and after they realize they was alone in a very cold place... they bagged to return to prision to survive.
    based in this, i make the option to select the small road with dashed line, as indicator of a very very smal road....
    But i understand your tip. Thank you.
    Lauti
