Ricko
Ricko
Ricko
6,731
Member
10,564
Birthday
February 7, 1977
merlo san luis argentina
Mapmaker
22
  • [WIP] Applevale
    In this small example, I've separated them into even more sizes, adding an extra, even larger, fifth line.
    Note a small detail: in topic 2, among the standard-size trees, there are some smaller trees. Compared to the others, where only the standard size is present, it gives a more "organic" and realistic appearance, at least to me.
    Trees behind and in front of the hills also contribute to a more harmonious view.
    QuentenMapjunkieMaidhc O CasainJuanpiLoopysueRyan Thomas
  • [WIP] Applevale
    To add more depth to the image, I suggest considering establishing 3 or 4 regions in the image (at least I usually do this) where the icons change size, each time a little larger.
    To avoid getting lost, I usually leave an example of the size outside the map as a reference if I need to go back to work on a previous area.
    Royal ScribeQuentenMapjunkieGlitchJuanpiLoopysueRyan Thomas
  • [WIP] Applevale
    Hey Royal, why don't you use a "water" sheet over the images to cover this passage and turn it into a waterfall?
    LoopysueRyan Thomas
  • Map for a friend part 34536....
    After some tweaks with the storyteller, here is the final result.
    LoopysueRyan ThomasRoyal ScribeTheIneffableCheeseMonsen
    This time a new map for my friend to master for his two daughters (8 and 6 years old) and his 9 year old niece. This time he asked me not to put names, as the names will be jointly created by his mini players.
    Cheers
    Royal ScribeLoopysueQuentenKertDawgMapjunkieRyan Thomas
