Ricko
Ricko
- Ricko
- 6,732
- Member
- 10,565
- February 7, 1977
- merlo san luis argentina
- Mapmaker
- 22
Reactions
[WIP] Applevale
In this small example, I've separated them into even more sizes, adding an extra, even larger, fifth line.
Note a small detail: in topic 2, among the standard-size trees, there are some smaller trees. Compared to the others, where only the standard size is present, it gives a more "organic" and realistic appearance, at least to me.
Trees behind and in front of the hills also contribute to a more harmonious view.
[WIP] Applevale
To add more depth to the image, I suggest considering establishing 3 or 4 regions in the image (at least I usually do this) where the icons change size, each time a little larger.
To avoid getting lost, I usually leave an example of the size outside the map as a reference if I need to go back to work on a previous area.
[WIP] Applevale
Map for a friend part 34536....
